Inner Tube Recomendation - Page 2 - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #16 of 19 Old 07-31-2019, 02:29 PM
Re: Inner Tube Recomendation
If it's a hangar queen tube it. If you're going to use it I'd get a pair of tires. Loosing a $12-$20 tube because you didn't spend $35 for a tire doesn't make sense to me. As I said they'll likely last another 30 or 40 years or so.
hatzie is offline
post #17 of 19 Old 08-07-2019, 07:58 AM
Daryl G
fireant911's Avatar
nate_o23,
If you do order a tube, would you be kind enough to report back on whether of not there was offset on the stem? I am trying to discern what is the proper 'TR' type as it looks like at least a couple are described as being offset (see - https://www.tireinnertube.com/conten...lve-stem-types) - TR13 or TR15???
Daryl G
1957 Gravely L
1974 Gravely C8
1973 Gravely CI
1967 Gravely C8
fireant911 is offline
post #18 of 19 Old 08-07-2019, 09:13 AM
Originally Posted by fireant911 View Post
nate_o23,
Right: If the rim is the type that will not allow mounting a tubeless tire (split rim) I would consider just drill a hole in the rim that matches up will a standard tube valve stem. You can put a piece of heavy tape over the old tube hole.
I've had to drill valve stem holes holes in tubeless lawn tractor rims so as to match carlisle type inner tubes. If ever go back to a tubeless tire I install another valve stem.
Have to keep a heads up now days about china type inner tubes that will not hold air when new. Good reliable inner tube will cost $12-15. (and if you do not install it yourself you have paid close to price of a new tire)
Forest Gump is offline
post #19 of 19 Old 08-07-2019, 05:09 PM Thread Starter
I ended up ordering tubes from chalmers industries. They did have a slight offset and they installed in the rim no problem. So far so good.
nate_o23 is offline
