Greasing the wheels on a 60 " freerolling deck on my 8199kt - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 2 Old 07-17-2019, 08:16 AM Thread Starter
REDGRAVELY 8199KT's Avatar
Hi Guys! These air type deck support wheels on my 60 " deck take a lot of grease!!! I gave each one 8 pumps with my Grease gun before grease started to squirt out. How often should these be greased?, after every use???
In it's day the six gun was as common as the cell phone and just as annoying when it went off in the theater!!! A Government strong enough to give you everything you need, is also strong enough to take everything you have!
REDGRAVELY 8199KT is offline
post #2 of 2 Old 07-17-2019, 08:35 AM
PA RedRider's Avatar
Re: Greasing the wheels on a 60 " freerolling deck on my 8199kt
I wouldn't even worry about it. Inspect the bushings and give them a thin coat. If worn out, replace them.
I swapped out the pneumatics on my 60" deck for solids years ago, so four less to chase with a compressor hose.
Thanks.
Looking for a home for:
Looking for:
- Onan-powered rider
- 14# wheel weights
PA RedRider is offline
