Gravely 430 Parts - Steering Gear - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 7 Old 07-08-2019, 08:57 AM Thread Starter
Is there a good place to find parts? I need the steering gear as the middle 'teeth' have worn down. I found one on ebay for $100 but I was wondering if there were alternatives from ebay or CL. Thanks!
ndl2485 is offline
post #2 of 7 Old 07-09-2019, 12:00 AM
Gravely 2-wheeler
Re: Gravely 430 Parts - Steering Gear
For new parts try Richard's https://www.gravelyparts.com/
For used parts I have had very good luck with Paul at Green Acres https://www.gravely.com/en-us/dealer...cres-power-319
Paul L
Gravelys: 1950 L, 1954 L, 1968 Comm 10A, 1969 C8, 1971 C8, 1984 5665
1967 430, 1969 432, 1980 8122
Craftsman 917.270670
PaulL is offline
post #3 of 7 Old 07-09-2019, 10:46 PM
Gravely1964
gravely1964's Avatar
You can save those gears. Basically you have to grind it shorter on the bottom and add a washer or washers to the top and it will drive the mesh tighter if its the old style gears and not the box. Check out my vid and or the 68 430 thread on mtf here
Start at 4:53 ish I get into the steering
Steven Turcheck
current tractors and rigs
1944 WWII L
48 L grw's
52 US navy L, 2 53 Ls
1950's Bready
74 cub 129& case 220
48 Willy's CJ 2A
1991 ford F150 and Bronco
2007 F250 Big White
2010 Sc2450 yanmar
gravely1964 is online now
post #4 of 7 Old 07-12-2019, 08:36 AM Thread Starter
Thanks for the video! This is an awesome fix - going to give it a shot this weekend. Haven't grinded metal before but we'll see how it goes.
ndl2485 is offline
post #5 of 7 Old 07-12-2019, 06:10 PM
Gravely1964
Main thing I will say is take your time and grind alittle at a time test fit. And try not to over grind, then have a whole bunch of washers top and bottom. But to fine tune it you can do that if needed
Steven Turcheck
1944 WWII L
48 L grw's
1950's Bready
48 Willy's CJ 2A
2007 F250 Big White
2010 Sc2450 yanmar
post #6 of 7 Old 07-15-2019, 08:01 AM Thread Starter
Unfortunately this did not work. The teeth were broken off and not worn down, so adjusting the height of where the gear fit into did not matter. I didn't notice until I had the part all the way off. Looks like I'll be going the way of the $100 used gear on ebay.
ndl2485 is offline
post #7 of 7 Old 07-15-2019, 05:40 PM
JohnWindl's Avatar
Any idea of what the gear specs are. It might be a standard from Boston Gear. Most bearing places can get them.
JohnWindl is offline
