G20 60inch deck starts and stop spinning - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 4 Old 06-20-2019, 10:12 PM Thread Starter
Bad day yesterday-first G18 stops running and then the 60 inch deck on my G20 blades starts and stops spinning. I noticed the grass was not being cut very well so I looked down and saw the blade spindle going fast, then slow, then fast, etc... I went to the barn and noticed the pto lever had no clearance at the front of the slot. I adjusted clearance to 3/4 inch and tried to mow-same problem. Two side notes-(1) tractor only has 265 hours on it,and (2) this happened once last year but after adjusting gap mower worked all last summer and this spring until now. I would suspect pto clutch but this would seem like a very early failure. I have plenty of room on the adjustment rod and may try to change gap both ways to see if there is a change.
addisongravely is offline
post #2 of 4 Old 06-21-2019, 11:13 AM
yamato72's Avatar
Re: G20 60inch deck starts and stop spinning
It doesn't take long for a mis-adjusted PTO clutch to wear out the lining. However, I would triple-check your adjustment procedure because it's easy to get it wrong and with such low hours it's more likely that the lining is fine.
yamato72 is offline
post #3 of 4 Old 06-21-2019, 03:34 PM Thread Starter
Today I tried adjusting the pto clutch again. I adjusted the rod a turn at a time in both directions. With a 3/4 inch gap it would act like before-started spinning quickly then turned very slowly. At all other adjustment gaps the pto would not turn at all, even with a one turn adjustment from 3/4 inch. There is also very little tension on the lever when engaging-but with a firm lever disengaging. The only thing I did not do per instructions was to lower safety switch bracket because I did not see how that would interfere with turning the adjustment rod.
post #4 of 4 Old 06-21-2019, 11:54 PM
The safety switch can prevent the transmission arm from traveling its full distance. It can literally hold the clutch in a slip or off position.
It is important to have it out of the equation until the PTO is adjusted.
Sheldon
ATLANTIC CENTRAL is offline
