Gravely 812 Dies with PTO Engaged or Any Load - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 5 Old 05-12-2019, 04:52 PM Thread Starter
Unhappy Gravely 812 Dies with PTO Engaged or Any Load
Hi All,
I have been having an issue recently where after receiving my 812 back from the repair shop, (deck fell off belly), any time there is load put on the engine it stalls and dies. I have now replaced: the head gasket (cylinder in good condition), fuel filter, carburetor (adjusted it), fuel pump, points, and coil. Not sure what the next steps are at this point. I used to be able to mow three foot tall brush climbing a 15 degree incline, but now I cannot even climb a slight incline or mow anything.
Any helps appreciated,
Ted
Gravely812... is offline
post #2 of 5 Old 05-19-2019, 09:16 AM
tracktortag's Avatar
Re: Gravely 812 Dies with PTO Engaged or Any Load
My first guess would be that the engine is not getting enough fuel under load. You might want to try readjusting the "high" needle outward (richer) a quarter turn, or so for starters. You might also want to double check the points to be sure that they are gapped at 0.20 in. Over the years, I have noticed that they tend to close slightly when tightened, and have had to readjust them.
Also, if you haven't already done it, you may want to take your carb. apart and clean it, including spraying all of the passages with carb cleaner using the straw. There are also tiny holes, barely visible, in the long needle that clog up. Try alternately spraying into them with the carb cleaner straw pushed against each of them. You should see carb cleaner spraying out of the others.
Finally, is it possible that the shop adjusted the governor? If so, it may have been done incorrectly, and may need to be readjusted.
Dave
tracktortag is offline
post #3 of 5 Old 05-19-2019, 01:32 PM
If it's running too lean you can do a quick test by pulling on the choke a little bit. If it runs better you know you need to be richer. It may help a little too when you try to put a load on it, but probably not much. There is no substitute for fuel, but choking the air off can be a troubleshooting tool.
franklin2 is offline
post #4 of 5 Old 05-19-2019, 01:56 PM
If it doesn't respond to a little choke as suggested,it might be the spark is weak--failing condensor if it has points,weak coil output,or corroded points can cause it to die under a load..
I have had some engines that would die under the slightest load,but run perfect sitting there with no load,and it turned out to be the fuel tank had a hose fitting with a fine mesh screen made into it,that was clogged and I had to tear it off and use a drill bit by hand to ream all the red silty rust out of the fitting,it was nearly completely blocked up..after that the engines ran great with much more power..
I've had old rubber fuel lines get mushy inside and form a clot too,ethanol does that to old hoses not rated for alcohol fuels..
Tractor-Holic is offline
post #5 of 5 Old 05-20-2019, 11:41 AM
WH401's Avatar
What do you mean by, "deck fell off belly?" I haven't seen where you've tried running the tractor without the deck installed, have you? Have you verified that nothing is bound, stuck, or stiff in the deck?
Rick
1960's-70's IH 340
1974 Gravely 816
1977 Gravely 817 (2)
1989 Gravely 20-G
199x Gravely 16-G
2000 Gravely Pro-14
2017 JD X758
WH401 is offline
My new Gravely 20g Hrc630 Gravely 55 05-08-2018 07:28 PM
John Deere 4720 PTO Problem billboyce2 The CUT Hut: General discussions of Compact Tractors 8 12-26-2017 04:05 AM
3184 PTO Won't Stay Engaged vortec Cub Cadet Forum 1 12-12-2017 10:40 PM
X540 Making noise with PTO off? bmurph44 John Deere Forum 25 01-09-2013 10:12 PM
99 gt235 PTO Issues garymows John Deere Forum 3 12-01-2012 03:05 PM
