-   Gravely (https://www.mytractorforum.com/24-gravely/)
-   -   Copper Head Gaskets (https://www.mytractorforum.com/24-gravely/1321343-copper-head-gaskets.html)
RI-GravelyMod 03-17-2019 08:16 PM
Copper Head Gaskets
2 Attachment(s)
What is your experiences using copper head gaskets?
I have one to install on a 7.6 & will anneal it before installation. Will torque to specs.
Good or bad, like to hear what has happened….
Thanks.
nhgravely 03-18-2019 10:00 AM
Re: Copper Head Gaskets
Where did you get the copper gasket?
Thickness?
Approximate price?
Have only seen the metal/fiber composite type and the fiber/mesh type.
Thanks
Sorry, didn't blowup photo to see you numbers!!
RI-GravelyMod 03-18-2019 01:10 PM
Approximate price?
I bought this off ebay a while back. The ebay seller still offers hundreds of copper gaskets but not L model. If this one works it may be worth contacting him.
Paid about $24.
I tried the aftermarket gaskets, but you have to replace them each time you remove the head.
Will post results......
Bodjick L 03-18-2019 02:33 PM
Would there be any dissimilar metals reactive issues with a head gasket?
gravely1964 03-18-2019 03:36 PM
I have been curious about this for years. I just never have bought one to try. The new fiber ones are total crap in my eyes.
Please do post the results and keep us posted
fireant911 03-19-2019 07:10 PM
I, too, am very interested in this! The last head gasket I purchased was purportedly out of a 'improved material' but I am less than impressed - it is way too stiff and I had some sealing issues from the get-go. I looked for some sheet copper earlier in hopes of fabricating my own but it was cost prohibitive...
RI-GravelyMod 03-20-2019 08:30 PM
Research used & found 2 major requirements, flatness and cleanliness is required above the normal rebuilding / tune-up requirements.
Of the (3) 7.6 heads I have, the one that was on the jug before rebuild is the best fit for flatness.
The other two heads rocked back & forth on the jug. The gap was about .008 around the center of the head (piston area). It was a surprise the warp & rocking was forward to rear direction on the jug.
Currently working to clean seating surface on head & jug. Objective is to have it as close as possible to new where you see the original mill marks.
I am at least a month out before the initial run. Need to order more parts……
nhgravely 03-21-2019 10:37 AM
I have had 6.6 and a 7.6 heads resurfaced as a matter of course on the two engines I am currently working on: 0.010" off the 6.6 head and 0.065" or so off the 7.6 head. The cylinders/jugs tend not to be so critical I believe because of the mass of the part compared to the heads which with the 6.6 are really pretty thin. I am using a copper coat gasket spray on the composite gaskets since you have to replace them each time anyway and if I can get a copper gasket, most surely would use a sealer of some type with them. If you have to do a valve job I would also recommend a light surfacing on the jug too, just to clean things up and give the valve cutter a new surface to start from.
RI-GravelyMod 03-30-2019 08:07 PM
2 Attachment(s)
Quick update....
Gasket installed, see pic. Details on installation will be later.
Rebuilding the dead carb, should be ready to run soon.
This tractor was a non runner sitting outside farmers barn.
HeyYou 04-07-2019 09:54 AM
Copper has a pretty low melting point.... Certainly well below combustion chamber temps.... It will be interesting to see how the copper gasket holds up.
nhgravely 04-08-2019 01:08 PM
Considering that nitro burning drag race engines use copper head gaskets, I don't think this will be a problem with the little low compression T head engine.
jrd 04-08-2019 02:23 PM
The cylinder and head are really good heat sinks. They'll keep the copper well below its melting point.
My air-cooled airplane engine produces exhaust temperatures approaching 1500F, but the head temps rarely get close to 400.
RI-GravelyMod 04-15-2019 03:58 PM
1 Attachment(s)
Fired up & ran today on the second pull. Runs like a new 7.6.
Ran for about 15 minutes and after cooling down I retorqued the head bolts. Only two turned, they were just outside of the center bolts.
I have to repair the swifty pivot pin in the axle assembly. Axles did not want to turn. Pivot pin is bent, recall this tractor was a non runner ready for parts…..
This is what I did to prep for the copper gasket:
Clean gasket seating surface on jug. You will see the mill markings when clean.
Check flatness of head and cylinder deck, I had to have the head ground
Clean bolt threads in jug. Used starter & bottom taps.
Anneal the copper gasket and then clean gasket with steel wool.
Use brake cleaner on cooper gasket, head, and cylinder deck.
Clean items multiple times till you have a clean rag drying them.
Measured threaded hole in jug, was about ¾”.
Check thread protrusion after inserting bolt in head with gasket on the bench.
I found with stock bolts the protrusion was a 3/8”, I discarded them and installed 1 ½” bolts.
Torqued head bolts to 25 ftlbs IAW 1970 CSD.
Ran engine for about 15 minutes and let it cool
Retorqued head bolts at 25 ftlbs.
Will run & retorque 2 more times.
nhgravely 04-16-2019 02:31 PM
They are back up on e-bay for sale right now.
RI-GravelyMod 04-17-2019 10:23 AM
4 Attachment(s)
I'd buy them again. Mine was purchased from "Copper Gaskets Unlimited" who sold them on ebay.
You should be able to reuse them, just have to anneal & clean.
Attached is a few pics.....
