Gravely Snowblower Question - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 3 Old 01-20-2019, 03:08 PM Thread Starter
stratocast56's Avatar
Can a snowblower off of a Gravely model 8163-G be used on a Gravely Model 20 G?
stratocast56 is offline
post #2 of 3 Old 01-20-2019, 04:08 PM
tracktortag's Avatar
Re: Gravely Snowblower Question
Yes, but the 20G would require a longer driveshaft (that runs between the PTO and the front axle shaft) than is used on the 8163. You would also need to find a longer 20G lift rod, or lengthen the lift rod used on the 8163.
Is it a 44 in. blower?
Dave
tracktortag is offline
post #3 of 3 Old 01-20-2019, 11:00 PM
Inveterate Putterer
Mikey4's Avatar
Older blowers were 38" and 44". Older tractors with single cylinder engines can turn the rear wheels in and thereby accommodate the 38" blower. Your 20G (along with the 18G and 16G) can only have the wheels turned outward, requiring the 44" or newer 48" blower.
The 8163 can use any Gravely blower - 38" and a 44" Snow Cannons and 40" and 48" Ariens-Style blowers - so you need to check which blower it is before you'll know if it will fit your 20G
Challenge Met
Gravely 16G (1998)
Gravely 16G (1994)
Gravely 16G (1991)
Gravely 816S (1976)
Mikey4 is offline
