Anyone's thoughts and comments on this one - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 6 Old 01-11-2019, 08:20 PM Thread Starter
MARK (LI)'s Avatar
I am thinking of taking a ride tomorrow to look at this one...it is an 8123...it does have a rototiller attachment also
https://www.facebook.com/marketplace...ssenger_banner
MARK (LI) is offline
post #2 of 6 Old 01-11-2019, 08:38 PM
tracktortag's Avatar
Re: Anyone's thoughts and comments on this one
Looks interesting, Mark. The "12" in 8123 means a 12 HP Kohler. FEL equipped tractors do command a premium, so 2K may not be out of the question if it's all in good condition.
Regarding the tiller, check to be sure that the rear PTO axle block, and block splined shaft are in place. Also, have the seller lay out the tiller's drive unit (attaches to, and drops down from the tractors PTO output shaft), and the driveshafts that run the power from the PTO drive unit back to the axle block shaft, and from the axle block shaft back to the tiller.
Also, he may have a 50 in. mower deck laying around too. It wouldn't hurt to ask. Good luck!
P.S. Are you taking the ferry over?
Dave
tracktortag is offline
post #3 of 6 Old 01-11-2019, 08:50 PM Thread Starter
MARK (LI)'s Avatar
Not taking the ferry...that costs a small fortune...although the tolls and long ride are no bargain either...thank you for the response
Where are you in NY?
post #4 of 6 Old 01-11-2019, 08:51 PM
L.I., like you.
Dave
post #5 of 6 Old 01-11-2019, 09:04 PM
Still lovin' the 322!
PA318Guy's Avatar
Mark, I echo the comments, looks interesting. The rams look nice and clean and that is always a plus on any of these. Test out all the functions and make sure to lift and dump a good load. That should let you know if pump and controls are working and tight.
Current Machine JD 322
PA318Guy is offline
post #6 of 6 Old 01-11-2019, 10:00 PM
Rebuilding my First JD GT
N2 Tractors's Avatar
Looks similar to the Wheelhorse D250 especially the rear plastic fender.
Running:
‘73 140 H1, ‘75 214, ‘79 JD 317 Onan P218G, 19xx Wheel Horse D250 550 Arc FEL ARPS Box blade
Not Running:
‘69 JD 140 H3, ‘75 JD 300, ‘79 JD 317 Kohler KT17QS II, ‘83 JD 420, late ‘80’s JD 316, ‘90 JD 316,
2x 300 series 3PH, Johnson Workhorse 12, Gannon Earthcavator 32”, 2x JD 54” 4way blade, 2x JD 33 Tiller + 8" Extension, JD 38” Brass tag mower deck, JD 48” mower deck, JD #30 Hydro Tiller, Disks, Plow, ARPS Angling Backblade,
N2 Tractors is offline
