16-G Governor settings - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 8 Old 01-10-2019, 02:45 PM Thread Starter
cfichuck's Avatar
I've seen it mentioned several times on this forum that the 16-G with the Magnum 18 engine came stock with the governor limited to 3300 RPM and that one can set it to 3600 RPM to achieve the full power rating of the engine. One thread, if I remember correctly, said the procedure was documented in a thread on this forum. I have searched but cannot find it. Can someone point me to the thread that shows how to do this, or post instructions on how to do it? Thanks much.
Chuck
Gravely 1984 5260
Gravely 1985 5260
Gravely 1991 Professional 8
Gravely 1986 5665
Gravely 1987 8163-G
Gravely 1990 16-G
IH-140
cfichuck is offline
post #2 of 8 Old 01-11-2019, 10:23 PM
Inveterate Putterer
Mikey4's Avatar
Re: 16-G Governor settings
The thread was by Sheldon (Atlantic Central). Not sure of the thread title.
Challenge Met
Gravely 16G (1998)
Gravely 16G (1994)
Gravely 16G (1991)
Gravely 816S (1976)
Mikey4 is online now
post #3 of 8 Old 01-12-2019, 10:13 AM Thread Starter
cfichuck's Avatar
I've searched in Sheldon's "Latest 16-G Improvements" thread using governor, speed, 3600, tach, tachometer, throttle, etc. but can't find it. Is there another thread by Sheldon that has it?
Chuck
Gravely 1984 5260
Gravely 1985 5260
Gravely 1986 5665
Gravely 1987 8163-G
Gravely 1990 16-G
IH-140
cfichuck is offline
post #4 of 8 Old 01-12-2019, 02:42 PM
Chuck, I never posted the step by step instructions.
But it is pretty easy to do.
Look at he picture below. There is an "L" shaped stop under the swivel arm that the throttle cable connects to. disconnect the throttle cable from this arm. Loosen that bolt, and reposition the stop to allow more travel until your tach says you are getting close to 3600 RPM.
Reconnect the throttle cable and re-adjust the other throttle cable clamp if necessary to get the throttle cable to pull the arm all the way to the new stop position.
If, and only if, the engine wants to hunt after this change, move the governor spring in one hole on the governor arm.
Double check max RPM and idle RPM and enjoy all the power Kohler designed into this engine......
Sheldon
ATLANTIC CENTRAL is offline
post #5 of 8 Old 01-12-2019, 04:21 PM Thread Starter
cfichuck's Avatar
Thanks Sheldon! I'll give it a try in the spring when I take it out of winter storage.
New question, anybody have a suggestion for a decent inexpensive tach?
Chuck
Gravely 1984 5260
Gravely 1985 5260
Gravely 1986 5665
Gravely 1987 8163-G
Gravely 1990 16-G
IH-140
cfichuck is offline
post #6 of 8 Old 01-12-2019, 06:31 PM
I bought my photo tach at Harbor Freight years ago, still works great....
Sheldon
post #7 of 8 Old 01-12-2019, 10:10 PM Thread Starter
cfichuck's Avatar
Thanks again Sheldon. I'll stop by Harbor Freight and see what they've got.
Chuck
Gravely 1984 5260
Gravely 1985 5260
Gravely 1986 5665
Gravely 1987 8163-G
Gravely 1990 16-G
IH-140
cfichuck is offline
post #8 of 8 Old 01-16-2019, 10:38 AM
WH401's Avatar
Depending on the year of your 16-G you may find you have to increase the length of the slot for the throttle lever in the dash. Late 80's G's have a shorter slot, later ones have a longer slot with a stop bolted on. On my 89' 20-G I had to file the slot slightly longer in order to lower the throttle lever enough to reach idle speed. Other than that, this simple upgrade has worked great for the last 4 years.
Rick
1960's-70's IH 340
1974 Gravely 816
1977 Gravely 817 (2)
1989 Gravely 20-G
199x Gravely 16-G
2000 Gravely Pro-14
2017 JD X758
WH401 is offline
