818T trans post-mortem - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 16 Old 10-31-2018, 01:00 PM Thread Starter
Finally removed my transmission to find out exactly why my Gravely left a chunk of cast iron and 6 qts of oil in my yard.
Differential bolt broke, and wedged between the gear and the case... cracked like an egg. The nut side of the bolt was still in the diff.
I wonder what kind of abuse this thing must have endured in a past life. :/
ID:	2343707   Click image for larger version
ID:	2343709   Click image for larger version
jj94tt is offline
post #2 of 16 Old 10-31-2018, 01:33 PM
200+ Posts!!!!
Tractors101's Avatar
Re: 818T trans post-mortem
Look's like a catastrophic failure, there. Probably gonna have to buy a new trans for the thing. I know for a fact that it is unwise to weld on cast-iron. I feel sorry for you because that probably was a nice machine.
Running:
Ford YT 16 ("Fast Mower")
53' JD 40 ("The Workhorse")
79' JD 111
Down For repairs:
70' IH 107 ("Katelyn")
41' Ford 9N
48' Farmall Cub
Toro 12/38 XL
Gold Yard Machines 22/46
old craftsman
Pushmowers:
77' Jacobsen 3 HP,
80's Craftsman 4.5 HP
4.5 HP yard machines
Newest: '86 Toro 21'' Pow'r drive
Parts: Craftsman 26 snowblower, IH 2165 HDS
"If you know what you're doing, then it can be done"
Tractors101 is offline
post #3 of 16 Old 10-31-2018, 02:07 PM Thread Starter
Yeah... it's too bad. Fortunately, transmissions with bad PTO clutches are a dime-a-dozen (it seems). Should be able to find a replacement pretty easily... except then I have to swap my PTO shaft. :|
jj94tt is offline
post #4 of 16 Old 10-31-2018, 02:16 PM
Rut
glrutkosx's Avatar
I have welded on good old cast iron as such with good success. If you clean it up and bevel the edges a bit . I pre heat the base metal and weld it with 7018 Rods,I know they are not cast iron rods but they have worked well for me for over 40 years welding rail cars . After welding it , I peen the welded piece a bit and heat it some more . Peen again and heat some more for a couple cycles of slowly cooling it. I have had success welding old cast iron water pumps with this technique ,and vises , and many other nothing to lose projects for folks to help them out . I would try repairing the case as it is not a heavily stressed area , it just broke from piece of gear tooth busting it out. I did use regular cast iron rods a few times when I had them available . But mostly 7018 rods running DCEP because that is what I had. Good Luck at whatever comes of it. I would weld it up for you if you were in my neighborhood ! I just like trying to save whatever I can from the scrap man.
glrutkosx is offline
post #5 of 16 Old 10-31-2018, 02:35 PM
Rut
glrutkosx's Avatar
There is a place that has videos on you tube concerning welding of cast iron . Muggy Weld dot com. They have an electrode I had never heard of before just for welding cast iron called a 77 electrode and it needs no fancy equipment . They have a lot of testimonials from customers who had success . Lots of cast iron on these old tractors so maybe check their videos out on you tube. I was impressed with what i saw.
post #6 of 16 Old 10-31-2018, 09:00 PM
Gravely1964
gravely1964's Avatar
Depending on which end of Pa your on I have a trans with a bad pto I'd let go of. Im in the west central end. Let me know , man does that stink though
Steven Turcheck
current tractors and rigs
1944 WWII L
48 L grw's
52 US navy L, 2 53 Ls
1950's Bready
74 cub 129& case 220
48 Willy's CJ 2A
1991 ford F150 and Bronco
2007 F250 Big White
2010 Sc2450 yanmar
gravely1964 is online now
post #7 of 16 Old 11-01-2018, 07:22 AM
jrd
Ouch.
I'm wondering what would cause that failure. There's no inordinate stress on those bolts, and nothing chafing on them or anything. It seems like it pretty much has to be a manufacturing flaw.
'41 L (not running)
'43 L
'44 L
'50 L
'52 L (not running)
'58 LI (not running)
'59 LI
'61 LS
'61 LS
Mutt LS
'62 LI (not running)
'63 L8
'66 L8
'66 C8
'67 C8
'74 Comm 12
'75 C8
'73 812
'74 816
UFT Mountaineer 88E
3 parts/project tractors
Too many attachments
jrd is online now
post #8 of 16 Old 11-03-2018, 11:02 PM
Gravelyyard.com
arcam8123's Avatar
Send a message via Yahoo to arcam8123
I have a couple of transmissions in MD, 20 miles south of Hanover PA.
Ron C
www.gravelyyard.com
www.gravelytractorclub.org
My Equipment: You're kidding, right? Not enough bandwidth on the planet.
arcam8123 is offline
post #9 of 16 Old 11-05-2018, 03:09 PM Thread Starter
Both hubs were in bad shape... keyways mashed up pretty good. I am not the original owner; I wonder if that differential would get worked extra hard if the tractor was used for pulling or something.
Thanks for the offers... but I found one local to SW PA. Now, I just have to swap PTO shafts (maybe switch to a red spring?). Oh, and my donor trans was not equipped with the hydraulic pump drive gear... had to pull that too.
ID:	2345039   Click image for larger version
jj94tt is offline
post #10 of 16 Old 11-06-2018, 02:13 PM
200+ Posts!!!!
Geez, those transaxles have A LOT of gears in them. Don't let anything fall out! I hope you succeed!
Running:
79' JD 111
Down For repairs:
41' Ford 9N
48' Farmall Cub
Toro 12/38 XL
old craftsman
Pushmowers:
77' Jacobsen 3 HP,
post #11 of 16 Old 11-09-2018, 12:35 AM
no2498's Avatar
from what i seen it was only a grade 5 nut&bolt
john
no2498 is offline
post #12 of 16 Old 06-12-2019, 03:47 PM Thread Starter
Clearly, I am not trying to win any races with the speed of this rebuild (my grass is thankful for the dependable 812), but it is mostly back together. Took this opportunity to swap to a red pto clutch spring and a set of tapered axles. The whole process was pretty simple with the use of an illustrated parts diagram that clearly indicates the parts on each shaft; lots of needle bearings and different size thrust washers. Having a donor trans was nice too, since I could pick the nicest gears and forks to use for my rebuild.
jj94tt is offline
post #13 of 16 Old 10-22-2019, 11:58 AM Thread Starter
So... this has turned into a fairly comprehensive restoration...
ID:	2402503   Click image for larger version
jj94tt is offline
post #14 of 16 Old 10-22-2019, 12:10 PM
yamato72's Avatar
VErY nICe
yamato72 is online now
post #15 of 16 Old 10-22-2019, 12:13 PM Thread Starter
Thanks!
Some before pics... and some things encountered along the way. I am not going to miss those straight axle shafts.
ID:	2402509   Click image for larger version
ID:	2402511   Click image for larger version
ID:	2402513   Click image for larger version
jj94tt is offline
