Difference Between a 16G and an 18G? - Page 5 - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #61 of 65 Old 09-05-2019, 10:58 PM
Re: Difference Between a 16G and an 18G?
I thought you were talking about a white color.
If red, someone told me about rustoleum sunrise red a couple years ago. My color consultant (spouse) has settled me on that as the closest she's seen.
Bodjick L is offline
post #62 of 65 Old 09-09-2019, 11:12 AM Thread Starter
Greyhome's Avatar
I picked up a can of the banner red from ace. Looks pretty darn close
Anyone have a favorite flavor of grease for the front wheel bearings?
Greyhome is offline
post #63 of 65 Old 09-12-2019, 03:27 PM Thread Starter
Greyhome's Avatar
Iím replacing wheel bearings and itís the first time I had the front end off the ground. I noticed a lot of vertical movement when lifting the week assembly up and down. I removed the steering arm and found what you see in the pic. The larger OD of the kingpin sticks up past the top of the axle beam causing the gap between the arm and the axle. I have the proper washer-thrust waster-washer stack on the bottom of the kingpin weldment but still have this gap on both the left and right sides. Is this normal?Click image for larger version
Greyhome is offline
Old 09-12-2019, 03:48 PM
yamato72
This message has been deleted by yamato72. Reason: Re-read the guy's question
post #64 of 65 Old 09-12-2019, 04:30 PM
Yes, it is supposed to be that way, yes, jacked up the spindles move up and down.
Sheldon
post #65 of 65 Old 09-12-2019, 10:16 PM Thread Starter
Greyhome's Avatar
Thanks much Sheldon. Waiting for bearing seals in the mail. Will assemble and put her back to work this weekend.
Sheldon
Greyhome is offline
