Best Gravely for rough bumpy mowing - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 10 Old 07-14-2018, 11:51 PM Thread Starter
cfichuck's Avatar
I have an IH-140 with a 60" belly mower that I've been using to cut around 2-3 acres of grass at my parent's house. it has been having some issues with stopping and not restarting lately, so I've finished up a few times with my 8163-G, and one time I did the whole area with it. It does the job, but I am beat up afterwards. The constant bouncing around over ruts, gopher mounds and just generally rough ground makes it not a very pleasant experience. The IH-140, of course has a much longer wheelbase and wider track that makes it more comfortable. I was mowing in third gear to get the job done faster, so I know that makes for a rougher ride, but the machine has enough power to handle cutting at that speed and I don't want to take all day with the job. Is there a model (24G?) that has a longer wheelbase or wider track, or is there something else I can do to make the experience more comfortable? Different tires, air pressure, maybe?
Chuck
Gravely 1984 5260
Gravely 1985 5260
Gravely 1991 Professional 8
Gravely 1986 5665
Gravely 1987 8163-G
Gravely 1990 16-G
IH-140
cfichuck is offline
post #2 of 10 Old 07-15-2018, 05:12 AM
Richard-tx's Avatar
Re: Best Gravely for rough bumpy mowing
The smoothness of the IH140 is due to the tire size.
Gravelys are a different class of machine. It is like comparing a golf ball to a basketball.
I leave the rest up to you.
Code:
                              Current Inventory
                              8183T (Onan B48)
Richard-tx is offline
post #3 of 10 Old 07-15-2018, 08:52 AM
Do you have a decent sized mower for one of your walk behinds? I found my old L with the sulky and the 40 inch mower way more comfortable than the 4 wheel mtd rider I was using. The rider was hard on my lower back when I hit bumps and holes and I would feel it the next day. When I started using the walkbehind with the sulky, my back problems went away.
All this happened by accident, I switched to the 2 wheeler with the sulky for other reasons. So I tried to figure out what the difference was, and found one difference was I was hanging some of my upper body weight on the handlebars of the 2 wheel tractor, so it supported my upper body some, while the steering wheel on the 4 wheeler lends no support at all. There may be some advantage also with the flexibility of the sulky hitch inbetween you and the tractor, but not sure about that.
Of course you will have a little more effort in turning a sulky/2 wheel setup. But I didn't have many turns or things to mow around in my situation. If you have a 2 wheel/sulky you can use, I would try it and see what happens.
franklin2 is offline
post #4 of 10 Old 07-15-2018, 10:40 AM Thread Starter
cfichuck's Avatar
I kind of knew that was the case even as I asked the question. My best course of action is probably going to be figuring out the trouble with the IH 140.
Chuck
Gravely 1984 5260
Gravely 1985 5260
Gravely 1986 5665
Gravely 1987 8163-G
Gravely 1990 16-G
IH-140
cfichuck is offline
post #5 of 10 Old 07-15-2018, 10:43 AM Thread Starter
cfichuck's Avatar
I do have a sulky and a 5665 with 40" mower. I've used the sulky in the past and didn't care for it. I have a number of hills and hillsides to mow and wouldn't care to be doing that on a sulky either. Thanks for the suggestion, though.
Chuck
Gravely 1984 5260
Gravely 1985 5260
Gravely 1986 5665
Gravely 1987 8163-G
Gravely 1990 16-G
IH-140
cfichuck is offline
post #6 of 10 Old 07-15-2018, 11:32 AM
GMT 9000 is a relatively large tractor (as garden tractors go). It provides for a MUCH nicer ride than my JD 216 could provide. Cuts a LOT faster too. (72" deck.)
HeyYou is offline
post #7 of 10 Old 07-15-2018, 05:11 PM
Professional Homeowner
steddy's Avatar
If you could look into a different manufacturer, Ferris makes zero turns with 4 wheel independent suspension. They ride like a Cadillac!
Otherwise, maybe try a suspension seat.
The sulky may have helped back problems also (wondering out loud here) because withthe sulky, you only feel the bump one time - when the sulky goes over the bump. When the 2 wheel tractor pulling the sulky hits a bump, you don't feel it quite as much. On a 4 wheel tractor, the front and rear tires hit the same bumps. You feel each bump twice.
Overkill.
I love overkill.
I'm Ted.
(Click Here)
steddy is online now
post #8 of 10 Old 07-16-2018, 09:32 AM
PA RedRider's Avatar
I like this idea. Longer frame, more weight and bigger deck. I know HelixHippie used to do some serious rough cut mowing with his.
Thanks.
Looking for a home for:
Looking for:
- Onan-powered rider
- 14# wheel weights
PA RedRider is offline
post #9 of 10 Old 07-16-2018, 10:01 AM
Choke's stuck on!
robhay2's Avatar
I second the suspension seat idea. I found one on ebay for like $99 with spring and adjustable shock. It makes a huge difference on the zero turn vs the standard hinged seat with 2 springs. Due to the frame and suspension components, it is about 5 inches taller, so it does effect your center of gravity and controls ergonomics.
robhay2 is offline
post #10 of 10 Old 07-16-2018, 07:55 PM
My GMT already has a suspension seat.....
HeyYou is offline
