30 in deck just pushes grass over - Page 2 - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #16 of 75 Old 05-22-2018, 09:26 AM
PA RedRider's Avatar
Re: 30 in deck just pushes grass over
The sloped.front guard with nose roller on the newer quick hitch 30" bush hogs is truly terrible. I removed mine and added a pair of Gravely deck weights.
Thanks.
Looking for a home for:
Looking for:
- Onan-powered rider
- 14# wheel weights
PA RedRider is offline
post #17 of 75 Old 05-22-2018, 09:39 AM
Richard-tx's Avatar
The front guard with roller aka "clamshell" was made in response to government safety regulations. There was no other way to make the 30" mower meet the requirements. Having said that, when using the mower for cutting grass, the quality of cut depends on the length of uncut grass being mowed. In long grass, the front guard does indeed push the grass over. Unless high lift blades (thin) are used, the grass will continue to lay over. Installing a old style guard will help but by modern standards, it renders the mower unsafe.
Code:
                              Current Inventory
                              8183T (Onan B48)
Richard-tx is offline
post #18 of 75 Old 05-22-2018, 09:50 AM
Gravely Frank McM's Avatar
I offer this strictly as an "historical observation", what anyone does with their own mower deck is strictly their business.
My Dad bought a new Gravely LI outfit in 1961; tractor, sulky, 30-inch rotary knife mower with the L-106 drive, rotary plow.
By the time I started using the machine to cut grass in the early 1970's, Dad had "customized" his mower thus:
> Removed the tall, rear "fender" and stored it (? I've never found it...)
> swapped short, front "fender" to rear of mower.
> Removed second blade and flanged washer, ran with single "grass blade".
After having acquired my my own Model L's with their 30-mowers, several with stock "fender" configurations, and using them, I have come to the conclusion that Dad did his fender swap because he found the tall rear "fender" tended to get hung-up on brush stubble, particularly when backing-up.
I have no hands-on experience with the later "sloping-front" 30-inch mowers, but just looking at them, I'm not impressed.
Back when the Howard County MD public schools had Gravely walk-behinds ( into the 1980's), most of their 30" mowers had the "chains" front guard... I always liked that idea, and some day will put some on my 30-inch mower decks.
Gravely Frank
Gravely Frank McM is offline
post #19 of 75 Old 05-22-2018, 11:35 AM
Richard-tx's Avatar
A picture of the mower in question will answer many questions.
Code:
                              Current Inventory
                              8183T (Onan B48)
post #20 of 75 Old 05-22-2018, 11:39 AM
Here-here... top & bottom...
post #21 of 75 Old 05-22-2018, 12:04 PM
cmeyers77's Avatar
Oh yes, weíll do so much like photos
cmeyers77 is offline
post #22 of 75 Old 05-22-2018, 12:38 PM
Gerrard's Avatar
Swapping-out the short guard sounds like a good idea or a great one actually because mine I took off was beat to heck, and if anyone has a question of how heavy duty these things are just take a BFH or a small 3 lb. hammer and try to knock the dents out of the rear guard, you wont have much success. I laid mine out on the deck and hit it w/a 3 lb. maul and it bounced back and about knocked my teeth out!
So I got a new one from Richards and it is a little shorter than the original one but I wish I would have just got a front one for the rear and run two front guards on it.
Im yet to get the front one but will soon.
There it is, new, primed and painted. I try to post pics with each post.
ID:	2290985   Click image for larger version
ID:	2290993   Click image for larger version
ID:	2291001   Click image for larger version
Gerrard is offline
post #23 of 75 Old 05-22-2018, 12:50 PM
Doing the front to rear guard move probably would allow a limited amount of clippings to discharge out the rear and also have added advantage of not hanging up on short stumps, etc.
I forgot to mention that the OP might consider a twin blade setup if finish mowing will be it's main use.
Thanks.
Looking for:
- 14# wheel weights
post #24 of 75 Old 05-22-2018, 12:54 PM
Gerrard's Avatar
Iv'e been seriously considering that to, I just wish someone had the so-called 'grass blade' AKA thin blade.
Gerrard is offline
post #25 of 75 Old 05-22-2018, 04:27 PM
Gravely Frank
Great minds think alike That is exactly how I have my mower set up. I actually tried mine with no guards, and that caused some sort of serious vibration in the deck.
Without the front guard you can actually come up on a small tree, ease into it, and the mower will actually chop it down if you go slowly.
franklin2 is offline
post #26 of 75 Old 05-22-2018, 04:53 PM
Richard's has a 5/16" thick "Medium" blade, Letter "C", on page 17 of their on-line catalog...
The OEM Gravely blades with the longitudinal ribs stamped in them tended to bow upwards towards the outer ends.
They would "get a smile in them"...
post #27 of 75 Old 05-22-2018, 05:31 PM Thread Starter
It is the standard 106 style deck. No guard on front.
perryg114 is offline
post #28 of 75 Old 05-22-2018, 07:31 PM
Gerrard's Avatar
Thats the one I got from Richards, he referred to it as the 'medium' one.
Cant find all the pics of it but it seems almost like it is a 1/4" to long on both ends but it could just look like that.
Well crap the upper pic on deck is the 3/8" brush blade and the lower one is the medium one. Im outside to get some instructions on putting fan assy and new bearings & shaft back together and am getting a glare problem
ID:	2291473   Click image for larger version
ID:	2291481   Click image for larger version
ID:	2291489   Click image for larger version
Gerrard is offline
post #29 of 75 Old 05-22-2018, 07:32 PM Thread Starter
See if this helps.
Perry
post #30 of 75 Old 05-23-2018, 08:07 AM
Richard-tx's Avatar
The blade in this picture is worn out. Scrap it.
Code:
                              Current Inventory
                              8183T (Onan B48)
