Clutch lining thickness - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 20 Old 05-24-2017, 07:41 PM Thread Starter
cfichuck's Avatar
Picked up an 8122 rider last week and was going over it to make sure all is good for a season of mowing. This is my first rider. One thing I'm unsure about is how thick the clutch lining should be on the forward/reverse clutches. I have pictures below of the forward and reverse clutches. The first picture is of the reverse clutch with the newer clutch assembly, and the lining on it looks to be about 3/8" thick. The second picture is of the forward clutch, and the lining on it is only about 1/16". Is the forward clutch lining at the end of its life, or does it have time left on it? How thick should it be when I replace it? Thanks.
ID:	1984506   Click image for larger version
Chuck
Gravely 1984 5260
Gravely 1985 5260
Gravely 1991 Professional 8
Gravely 1986 5665
Gravely 1987 8163-G
Gravely 1990 16-G
IH-140
cfichuck is offline
post #2 of 20 Old 05-24-2017, 08:52 PM
Re: Clutch lining thickness
The forward clutch lining is in serious trouble. Those linings are riveted on and you may well be down to the rivets.
They are easy to remove for inspection and repair. Loosen and remove the adjustment nut at the top of the bar, remove the bar by sliding it up. The clutch assembly will then slide off the transmission spline shaft. Note the spring on the shaft under the clutch assembly.
Hopefully the hub on the transmission is not damaged. If it has wear marks or residue from contact with the aluminum rivets, it may be possible to sand it smooth with Emory cloth. More serious damage will require transmission disassembly to replace the hub.
The lining can be replaced by drilling out the rivets and installing a new lining - GRAVELY still sells the parts.
Check the bearing in the clutch assembly for smoothness, lube the spline shaft very lightly on re-assembly.
Others may have photos they can post......
Sheldon
post #3 of 20 Old 05-24-2017, 11:48 PM
PA RedRider's Avatar
A good guideline is when the lining is worn to the thickness of your ignition key, it's time to reline or replace. Yours looks overdue.
Thanks.
Looking for a home for:
Looking for:
- Onan-powered rider
- 14# wheel weights
PA RedRider is offline
post #4 of 20 Old 05-25-2017, 07:33 AM Thread Starter
cfichuck's Avatar
Can I use the glue on lining instead of the riveted one? I don't have a rivet gun nor know how to use one.
cfichuck is offline
post #5 of 20 Old 05-25-2017, 07:39 AM
Richard-tx's Avatar
Originally Posted by cfichuck View Post
can i use the glue on lining instead of the riveted one? I don't have a rivet gun nor know how to use one.
no
Code:
                              Current Inventory
                              8183T (Onan B48)
Richard-tx is offline
post #6 of 20 Old 05-25-2017, 08:21 AM Thread Starter
cfichuck's Avatar
no
Back to school, then! Anyone know of any good resources, especially pictures and videos, that could guide me?
cfichuck is offline
post #7 of 20 Old 05-25-2017, 10:36 AM
Call Richard's and order a relining kit. It will include the correct rivets (with a few spares) and a roll pin spacer. Then pickup a pop rivet tool for downspout work.
Thanks.
Looking for:
- 14# wheel weights
post #8 of 20 Old 05-25-2017, 02:40 PM
4K Poster and climbing!!!
Canary Al's Avatar
A pop rivet gun slides onto the pop rivet over the longer smaller end.
As it being held in place as needed to fasten, the handles are compressed exactly as in squeezing the handles of a set of pliers.
The action creates a pulling of the long, smaller end out from the inside of the rivet. This causes a spreading of the rivet as it breaks away sealing the two pieces (liner & clutch disc) together.
If you can use pliers you can operate a pop rivet gun. Look at each of these links to help this make sense.
Oh and a pop rivet gun is not very expensive.
https://www.google.com/imgres?imgurl...act=mrc&uact=8
“Failure is simply the opportunity to begin again, this time more intelligently.”- Henry Ford
1992 - 20G-Kohler Magnum Twin (KMT) M20 big Red
1981 - 8183-repowered w/97 M18S 'lil Red
1972 - 816-repowered w/92 M18S 'lil white
1987 - Pro-12 Mr. Lucky
1984 - 8122 to get a diffrnt K301 soon.
1982 - 8123 Fred's Tractor an adoptee
1974 - 812 which is donating.
1970 - 450 w/CCKA Old Yellow
1968? - 424 - shared toy w/Grandson
1974 - C10A - for sale
1961 Ford Industrial 4000 w/Bkhoe-FEL
Canary Al is offline
post #9 of 20 Old 05-25-2017, 08:09 PM
I was under the impression you could rivet or glue new linings on?
Sent from my SAMSUNG-SM-G900A using Tapatalk
steved is offline
post #10 of 20 Old 05-25-2017, 08:41 PM
Richard-tx's Avatar
Only on the 800/8000 tractors. On the G series, rivets are the only way to go. Once you do it you will wonder why you made such a fuss. Just taking the glued on lining off is a chore.
Code:
                              Current Inventory
                              8183T (Onan B48)
post #11 of 20 Old 05-26-2017, 07:39 AM
Gravely bug bit.
cfichuck, Where in Ohio? Richard's is about 90 minutes SE of where I'll be in a couple weeks. If that clutch has worn a ridge in the hub, just a new lining is not going to help. If it hasn't, then I'd suggest swapping the discs now as the reverse clutch gets the least wear. That would get you thru till you get the parts needed. Changing the inner hub is not a quick job as you have to remove a snap ring from inside the tranny. Here is what the insides look like. But as it is the forward clutch hub that would need replaced if worn, it resides in the cover so you don't have to take all the shafts out. You do have to worry about losing the bearings inside the tranny though. Each one of the shaft ends you see has a bearing on it. Many stay in the cover if they are well behaved.
Current L/C count = 38.
Fla Don is offline
post #12 of 20 Old 05-26-2017, 08:24 AM
On an 8000 series that's true, which the OP's machine is, but most folks I know with 8000 series tractors with the original glued linings have switched to riveted when the time came to replace.
Thanks.
Looking for:
- 14# wheel weights
post #13 of 20 Old 05-26-2017, 12:49 PM Thread Starter
cfichuck's Avatar
Mine is actually a glue on lining. The new linings are 3/16" (I've got one from Richard's), so with a little more than 1/16" on my existing lining, maybe it's not in such bad shape? Why do people switch to the riveted lining when replacing them?
Chuck
Gravely 1984 5260
Gravely 1985 5260
Gravely 1986 5665
Gravely 1987 8163-G
Gravely 1990 16-G
IH-140
cfichuck is offline
post #14 of 20 Old 05-26-2017, 12:54 PM Thread Starter
cfichuck's Avatar
Don, I'm in Cincinnati. Someone else suggested switching the clutches. But being glue-on and more than a 1/16" left, does the lining really need to be replaced right away? The new ones are only 3/16"
Chuck
Gravely 1984 5260
Gravely 1985 5260
Gravely 1986 5665
Gravely 1987 8163-G
Gravely 1990 16-G
IH-140
cfichuck is offline
post #15 of 20 Old 05-26-2017, 01:17 PM
At a minimum, I'd swap the forward and reverse clutches. With the forward clutch being used 90% of the time, it will postpone relining, perhaps for quite a while. Certainly get you through the end of this mowing season, when there will be ample time to do maintenence. Just depends if this is your main mowing tractor and if you have a backup.
Thanks.
Looking for:
- 14# wheel weights
