38 inch blower squeal - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 3 Old 03-14-2017, 07:18 PM Thread Starter
Ok, blowing the heavy snow today...got about 16 inches.
About half way through, the PTO would squeal when the blower was lifted (manual lift), and would subside when the PTO was kicked out. I thought it was the driveshaft rubbing the washer on the lift arm...so I swapped to a smaller washer. That helped for a few passes then started again...it may still be something like that, and I have to look at that; but it sounds like a bearing locking up.
I just don't understand why lifting the blower makes it happen. The stub shaft has new bearings, so that's unlikely the source. I'm thinking it's a bearing in the cast section of the blower...is that common?
Sent from my SM-T350 using Tapatalk
steved is offline
post #2 of 3 Old 03-14-2017, 09:43 PM
Re: 38 inch blower squeal
Sounds as if you safety clutch has worn down some and needs readjusting.
What model tractor, what model snowblower?
Faux Pas are my forte
beaner2u is offline
post #3 of 3 Old 03-15-2017, 08:28 AM Thread Starter
No safety clutch other than for the reels, this is the 38 inch blower on a rider.
Sent from my SAMSUNG-SM-G900A using Tapatalk
steved is offline
