60 inch deck spring assist pins - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 8 Old 03-03-2017, 05:04 PM Thread Starter
I am installing a 60 inch mower on a G-20 but there are no spring assist pins on the tractor. I have looked in the parts manual for a part number but the pins are not shown. Does anyone have part number or source? The pins go just aft of the front side panels and are installed in the bottom hole which is threaded. thanks for any help.
addisongravely is offline
post #2 of 8 Old 03-03-2017, 06:05 PM
Re: 60 inch deck spring assist pins
You need the longer pins for a G-SERIES I'm looking for the P/n.
The short pin is 11279P1
Sent from my XT1585 using Tapatalk
my stuff
1987 8123 40"
1974 816 50", rear liftable hitch PTO, steering brakes, front PTO, snowplow, R&P steering
1977 817 50"
1983 8179KT 50", front PTO
1989 12G 40"
1995 18G 50" mulch kit, 3 can bagger steering brakes
1989 20G 50", rear liftable hitch PTO, steering brakes, front PTO
Pro8 Robin 9hp repower
Pro8
Dads stuff
1967 430 40", front PTO/30", rear liftable hitch
1978 812 40"
1990 16G 50"
1992 16G 50", snow plow, steering brakes
1989 24G 72"
2015 Gravely Atlas JSV3000
5665
Some walk behinds
my brothers stuff
1936 D Model
UFT Mountaineer 88E 30" deck, rotary plow
Pro16 40" 3-blade, 40" kidney bean,snow plow
Pro16 50" rigid mount, power brush
1996 16G 50"
lt4xtreme is offline
post #3 of 8 Old 03-03-2017, 06:09 PM
31688 is the P/N for the long pin for a G-SERIES. It's listed in the 60" deck manual.
my stuff
1987 8123 40"
1977 817 50"
1989 12G 40"
Pro8
Dads stuff
1978 812 40"
1990 16G 50"
1989 24G 72"
5665
Some walk behinds
my brothers stuff
1936 D Model
1996 16G 50"
post #4 of 8 Old 03-03-2017, 08:27 PM
PA RedRider's Avatar
I inquired about these at Jack's a while back and they were NLA. Good luck with that one.
Thanks.
Looking for a home for:
Looking for:
- Onan-powered rider
- 14# wheel weights
PA RedRider is offline
post #5 of 8 Old 03-03-2017, 09:29 PM
Still a good number but $26 each.
my stuff
1987 8123 40"
1977 817 50"
1989 12G 40"
Pro8
Dads stuff
1978 812 40"
1990 16G 50"
1989 24G 72"
5665
Some walk behinds
my brothers stuff
1936 D Model
1996 16G 50"
post #6 of 8 Old 03-03-2017, 11:13 PM
Inveterate Putterer
Mikey4's Avatar
I made my own a few years back. They work fine. In this picture you can see them next to the shorter 800/8000 size bolts. I got 3-1/2" grade 8 bolts, two nuts, and a short length of tubing. I drilled a few holes into the tube to allow me to weld it in the middle in addition to the ends. Slip the tube over the bolt. Set the nut to the proper depth and tack weld in two spots. Butt the tube to the nut and weld it. Weld through the holes and then weld the other end. Clean up the welds at the now-formed groove beneath the bolt head and you're done.
Not so pretty but they're still on the tractor and haven't bent at all. I used the washers to protect the tractor's paint. Next time, I would use tubing with thicker walls.
You also need to bend the handles of the latches so the clear the side of the tractor grill. You can that in the picture, too. Those are very old 400 series latches. The ones for the G tractors are identical except for the handle bends.
I tried to make the links, too, but one of these later failed (rather spectacularly). The were made from the biggest mending straps I could find at the hardware store. Ooops!
Challenge Met
Gravely 16G (1998)
Gravely 16G (1994)
Gravely 16G (1991)
Gravely 816S (1976)
Mikey4 is offline
post #7 of 8 Old 03-04-2017, 12:56 AM
Gerrard's Avatar
Sure looks good to me, as good as the original. If you can make stuff like that I wouldnt bother looking for replacement parts.
Gerrard is offline
post #8 of 8 Old 03-04-2017, 12:11 PM Thread Starter
Thanks for the information. I found the part at 3 websites-all at the price you mentioned. The part number has been updated to 08729600.
