Fuel gage float won't float - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 17 Old 10-03-2016, 12:37 PM Thread Starter
I have a ZT 48 and the gas gage sits at empty despite the level of fuel in the tank. I have removed the gage and the float will move up and down the gage freely. The needle also correctly reflects the position of the float. For whatever reason, it seems the float will not float. I had thought about attaching cork or something of that nature to the float, but I wouldn't be able to get the gage assembly back into the tank. The cost to replace this gage is about $40. So, short of replacing the gage (really don't like that option as it's likely to fail again), does anyone here have any advice on how to repair the existing gage or where to find a less expensive replacement?
Greyhound101 is offline
post #2 of 17 Old 10-03-2016, 06:52 PM
Re: Fuel gage float won't float
Did the float spring a leak, fill with gas, and become a 'sink'?
Might try pulling it out of the tank, drying if off with a clean rag, and then holding it in various orientations to see if gas starts dribbling out somewhere..... Once you know where the problem is, you can decide on how best to fix it.
HeyYou is offline
post #3 of 17 Old 10-03-2016, 07:02 PM
Richard-tx's Avatar
All of the new gas floats don't float so good and they haven't been good for over 2 years. I gave up on them altogether. The best fix is to just look inside the tank for a gas level.
Code:
                              Current Inventory
                              8183T (Onan B48)
Richard-tx is offline
post #4 of 17 Old 10-03-2016, 07:53 PM
Gravely1964
gravely1964's Avatar
On any of the zero turns new ish you have to put gas in and then tap gauge with finger to jolt it to level. why but there all like that. Best guess is while its easy for us to move by hand theres not a ton of force applied by the fuel movement.
Steven Turcheck
current tractors and rigs
1944 WWII L
48 L grw's
52 US navy L, 2 53 Ls
1950's Bready
74 cub 129& case 220
48 Willy's CJ 2A
1991 ford F150 and Bronco
2007 F250 Big White
2010 Sc2450 yanmar
gravely1964 is offline
post #5 of 17 Old 10-04-2016, 10:56 AM Thread Starter
I pulled it from the tank and blew it dry with compressed air. I dipped it back in the tank and removed it again but could not detect where it may have been filling up with gas. Gas would not drain from the float so I couldn't determine if it was holding gas or if it wasn't but simply won't float.
This mower has less than 80 hours and the float hasn't worked in the past 20 hours so it's kind of aggravating that it didn't last any longer than it did.
post #6 of 17 Old 10-04-2016, 11:56 AM
Warranty?
HeyYou is offline
post #7 of 17 Old 10-04-2016, 02:34 PM Thread Starter
Warranty?
Unfortunately, it's out of warranty.
post #8 of 17 Old 10-04-2016, 07:30 PM
Daryl G
fireant911's Avatar
Greyhound101,
I would contact Gravely directly about this issue. - I would be willing to bet that they will take care of this problem for you. Give them the details you included here. Their business is the have happy, repeat customers and if there is an issue with the reliability of this component they certainly need to know.
Daryl G
1957 Gravely L
1974 Gravely C8
1973 Gravely CI
1967 Gravely C8
fireant911 is offline
post #9 of 17 Old 10-05-2016, 09:33 AM
Richard-tx's Avatar
Gravely dores no make the fuel caps. They are made by another company that specializes in fuel stoage and delivery systems. My guess is that they changed plastic type due to the amount of ethanol in the gasoline. I think the only solution is to fashion your own from either brass (think carb float) or cork. The other option is to put a real electric sending unit and gauge on the machine.
eGauges.com - Auto Meter, Classic Instruments, Defi, Isspro and VDO Gauges, Senders, Mounting and Accessories
Code:
                              Current Inventory
                              8183T (Onan B48)
post #10 of 17 Old 08-13-2019, 03:13 PM
Exact same problem here. The float is a solid foam casting. I am guessing it's saturated,too heavy to work. Perhaps it's an ethanol issue. $70 on Amazon,$45 at the dealership. Not worth it considering where my fill cap is located. Looking for a fix and disappointed. Any ideas ?
BigEric is offline
post #11 of 17 Old 08-13-2019, 05:24 PM
Collector of many tractors
Kbeitz's Avatar
Bake it in the sun a few days. The seal it with gas tank sealer...
Kbeitz is offline
post #12 of 17 Old 08-13-2019, 05:54 PM
RT3360's Avatar
Fuel senders are typically closed cell foam nowadays and have been for nearly 40 years. Does the float slide up and down or does it have an arm with the float at the end? If it’s the latter, there are adjustable senders that can be set to the depth of the tank, but you will need to match the sender resistance. There are only a few standard resistances. Some of these senders come with the float separate. If you can find one of those, you could just swap the float with the one you have. It may not read perfect, but at least it will read in the ballpark. Hope this helps.
Craftsman DLT2000, 48”
Ariens ST824 snowblower
RT3360 is online now
post #13 of 17 Old 08-13-2019, 06:57 PM
close enuff works for me
deereboy55's Avatar
A paint stir stick is inexpensive,and wont lie about the gas level
deereboy55 is offline
post #14 of 17 Old 08-13-2019, 08:26 PM
Unless someone drops a rock in your gas tank, right where the stick hits......
HeyYou is offline
post #15 of 17 Old 08-14-2019, 12:54 AM
Gravely 2-wheeler
Same as Kbeitz and the sealer I use is a couple of coats of shellac.
Paul L
Gravelys: 1950 L, 1954 L, 1968 Comm 10A, 1969 C8, 1971 C8, 1984 5665
1967 430, 1969 432, 1980 8122
Craftsman 917.270670
PaulL is offline
