1845c has drive issue - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
Construction Equipment A Forum for the Big Boys Toys of All Sizes (Excavators, TLB's, Dump-Trucks, Dozers, Backhoes, etc.)
post #1 of 3 Old 10-13-2019, 09:29 PM Thread Starter
Question 1845c has drive issue
Skidsteer lost drive and rolled towards house.Had to turn off ignition to stop my machine.recently replaced line with a made to order cut and fitted replacement line from dealers shop,heard that sometimes they don't clean out all the shavings and these can be the source of a problem.
Jeff kro is offline
post #2 of 3 Old 10-13-2019, 10:41 PM
Cat385B's Avatar
Re: 1845c has drive issue
Did you pop a cover and make sure you didnít pop a drive chain?
Cat385B is online now
post #3 of 3 Old 11-02-2019, 06:27 PM
sonny's Avatar
Don't see how shutting engine off would stop anything! ---Not much details here to give a good idea, but, Check the new hose to see if it blew off, Is there air in the drive system? --- You didn't say which hose was replaced. ---- The wheel drive has 2 systems, one for each side, so loosing only one side will not make it run away. Each side is self-contained unit.
Not likely that drive chains would come off, even if they did shutting engine off would not stop the loader.
Check everything super good, and tell exactly what you find, we will try to help you but need specific info! Thanks!
http://machinebuildersnetwork.com/
sonny is offline
