John Deere 410 Backhoe - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
Construction Equipment A Forum for the Big Boys Toys of All Sizes (Excavators, TLB's, Dump-Trucks, Dozers, Backhoes, etc.)
post #1 of 1 Old 05-19-2019, 11:18 PM Thread Starter
Sears tinkerer
ban_four's Avatar
Hey Guys,
I have a new to me 1979 JD410. It was running well when my neighbor parked it about 10 years ago. I drained the fluids in preparation of trying to start it again and have hit a snag. I can't turn the engine over by hand. The starter was toast so can't try bumping it that way either.
Once I discovered it was seized I have:
Removed injectors and used 50/50 ATF a and acetone mix in each cylinder.
Removed valve cover to look for issues (didn't find anything it looks brand new in there)
No water in the oil.
Ran a Milwaukee m12 camera in the injector holes, inside cylinders were carboned but not unusually dirty, no rust.
Tried an impact on low setting on crank pulley bolt for some jarring action. No dice.
Loosened belt and turned fan and alternator by hand to confirm they weren't the culprit.
Disconnected the hydraulic pump so it's not holding me back.
Ratchet strapped the clutch pedal all the way down.
I have the reverser in neutral, hi/lo selector in neutral, gear shift out of gear too.
What else could be the issue here?
I have not pulled the head yet but may not have a choice.
Any suggestions?
ban_four is offline
John Deere 260 backhoe machineryman1945 John Deere SCUT 16 01-17-2019 11:05 AM
John Deere 14SB questions bwdbrn1 Walk Behind Mowers 36 10-03-2018 09:08 PM
John deere 400a backhoe Krille BIG John Deeres 4 08-12-2018 07:41 AM
1993 John Deere 410D Turbo 2wd backhoe .. Transmission Problem shotguns BIG John Deeres 2 11-06-2017 06:59 AM
