John Deere Push Mowers - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 37 Old 11-08-2015, 09:15 PM Thread Starter
KDL
KDL's Avatar
Hi All,
I'm on the hunt for a new used push mower and I understand some of the older JD mowers are the ones to look for. I am not familiar with many of them and there seems to be quite a few different models out there. Would it be possible to put a list together of the most desirable models to the least, along with some of the key features of each? I realize the list would be subjective but it sure would help weed through the different mowers that come available from time to time. Thanks so much for the help.
KDL is offline
post #2 of 37 Old 11-21-2015, 10:32 PM
MTF Tractor Nut
wizzo's Avatar
Re: John Deere Push Mowers
In JD green:
JX-85 commercial duty with the metal wheels
JX-75
In JD silver jubilee:
14SX or 14SC commercial duty with the metal wheels, one version doesn't have the BBC...
14SB
14SE if you're into electric start
There are newer models that'll be in JD green, but I believe the ones above are what you want. The JX and the 14S models use the same style aluminum deck so they don't rust like steel decks. There are also some zone start 14 models (where you must be standing at end of the handles to start mower) also. There is also a rarer Briggs and Stratton two-cycle version of the 14s that I believe are 12xx models. The JX and 14SX/SC/SB/SE all have Kawasaki engines. The JXs are also newer than the 14S models and some have larger Kawasaki engines on them.
2010 John Deere X500
  • 48X w/ Mulch Kit, Gators & HDAPs
  • Brinly Plug Aerator, JD Spreader & 10p Cart
  • 48" Front Blade, Wheel Weights & Suitcase Weights
  • 30" Mechanical Tiller
1994 John Deere 14SB
2000 John Deere JX75
Stihl KM 90R Kombi System
2005 Lawn Boy 10684 Insight Mower
wizzo is offline
post #3 of 37 Old 11-22-2015, 08:19 PM Thread Starter
KDL
KDL's Avatar
Thank you so much for the reply.
What is the difference between the JX-85 and the 75? Are the 14 all very similar?
I will keep this list handy for reference while the search for the perfect mower continues. Thanks again!
KDL is offline
post #4 of 37 Old 11-24-2015, 12:09 PM
MTF Tractor Nut
wizzo's Avatar
The JX-85 is a commercial use variant of the JX-75. It has steel wheels instead of yellow plastic, metal guards around the wheel height adjust positions, metal guards around the deck edge on left & right (help with wear against edging, stone, etc), and it has an oil filter. Most of these features can be added to the JX-75 with some minor mods. Here are some good links with pictures.
JX-85
https://www.mytractorforum.com/155-wa...oly-grail.html
Adding to JX-75
https://www.mytractorforum.com/155-wa...-upgrades.html
wizzo is offline
post #5 of 37 Old 11-24-2015, 07:11 PM Thread Starter
KDL
KDL's Avatar
Thanks for the info and links. More good information.
If you come across a mint JX-85 send it my way.
KDL is offline
post #6 of 37 Old 11-26-2015, 04:29 PM
Stx30's Avatar
I had a JX 65 (overhead valve Briggs) I loved it. The transmission quit so I gave it away. They have a great cut.
John Deere 1967 110 Round Fender
Lawn Boy 10590 M
Lawn boy 10515 SP F engine
Lawn boy 1015 edger
Lawn Boy Brick tops assorted
Stx30 is offline
post #7 of 37 Old 12-03-2015, 12:03 AM
MTF Tractor Nut
wizzo's Avatar
I didn't mean to say anything bad about the newer JDs.... Its usually the 14S_ or the JX75/85 that people are looking for. A lot of people seem to like the zero turn front wheels on the one of the newer models.
wizzo is offline
post #8 of 37 Old 12-07-2015, 12:21 AM
Zee01's Avatar
I've got a WE-85. It has to be one of the heaviest 21" walk behinds I've ever used. It gives the nicest cut and has the most power of anything I've used in that size too.
Zee01 is offline
post #9 of 37 Old 12-07-2015, 09:00 PM Thread Starter
KDL
KDL's Avatar
Thanks for the info. Didn't know about the WE series.
KDL is offline
post #10 of 37 Old 12-09-2015, 03:52 PM
SilverDeck's Avatar
Here's some useful information I've collected and compiled on the 12 and 14 series "silver deck" John Deere mowers. (I welcome and corrections/additions to the list)
John Deere 12 & 14 Series Walk-Behind Mowers
Decoding the Model Numbers:
1 = 21 mower
2 = 2-cycle engine
4 = 4-cycle engine
S = self-propelled
P = push
Z = zone start
B = BBC (blade brake clutch)
E = electric start w/ BBC
T = Tricycler (mulching)
C = commercial
X = commercial w/ BBC
So a model 14SB indicates 21", 4 cycle, self-propelled, blade brake clutch; 14PZ indicated 21", 4 cycle, push, zone start; etc., etc.
These mowers were made with two different 4-cycle engines, the Briggs & Stratton Quantum (on the less expensive models), and the Kawasaki FC150V on the more expensive models.
On the self-propelled models, there are two transmission types: 2-speed and 5-speed. Both are made by Tuff Torq (Kanzaki). The Briggs engine models used the 2-speed and the Kawasaki engines used the 5-speed. None of the Briggs engine models used the BBC blade control. Blade control was only available on Kawasaki engine models (like the 14PB).
The Tricycler was a unit set up from the factory for mulching. It came with a mulching plug and a grass bag. A Tricycler conversion kit was also available as an accessory. Mulching Kit BM17484 included a mulching plug (M112582), mulching blade (M125413), and rear cover decal (M112911). Conversion Kit BM17497 included these items plus a Tricycler label (M113068) and the side discharge chute (M76488).
The commercial models (12PC, 14SC and 14SX) had steel wheels for durability.
12PB:
1990-1991
Briggs & Stratton 2-cycle engine (96722 I/C)
Push
Recoil start
Briggs Magnetron Ignition
12PC:
19??-19??
(Commercial model)
Push
Recoil start
12SB:
1989-1992
Self-propelled (5-speed)
Recoil start
14PB:
1989-1993
Kawasaki FC150V 4-cycle engine
Push
Recoil start
Blade Brake Control
Flywheel magneto ignition
14PT:
1993-1994
Push
Recoil (zone start)
14PZ:
1991-1997
Briggs & Stratton 4-cycle engine (122700 series)
Push
Recoil (zone start)
14SB:
1989-1997
Recoil start
Blade brake control
Pressurized lubrication
14SBs:
1997
Recoil start
Blade brake control
Splash lubrication
14SC:
1993-1994
(Commercial model)
Recoil (zone start)
14SE:
1989-1997
Electric (key start)
14ST:
1993-1994
Self-propelled (2-speed)
Recoil (zone start)
14SX:
1995-1997
(Commercial model)
Recoil (zone start)
Blade brake control
14SZ:
1991-1997
Briggs & Stratton 4-cycle engine (122700 or 124700 series)
Recoil (zone start)
SilverDeck is offline
post #11 of 37 Old 12-09-2015, 07:28 PM Thread Starter
KDL
KDL's Avatar
SilverDeck,
Wow! That list is fantastic! Just what I was looking for. Now when I see one listed for sale I'll know exactly what it is.
Thanks again!
KDL is offline
post #12 of 37 Old 01-09-2016, 08:31 AM
If you are interested in either a 14SB or a JX75 I will have both for sale very soon as my JX85 will be my primary mower in the Spring.They are both in beautiful condition.
Where you are in Mass it woun't be quite the ride I went to-to pick up the '85.
Jeff
JCturboT is offline
post #13 of 37 Old 01-09-2016, 06:11 PM Thread Starter
KDL
KDL's Avatar
Jeff
I'd be interested. Send me a PM with details. Thanks!
KDL is offline
post #14 of 37 Old 01-09-2016, 06:42 PM
Proud Wheel Horse Owner
austinado16's Avatar
I too am a huge fan of the cast deck JD's with Kawi engines. Extremely well balanced, and give a great cut. I've had, worked on/rescued, and flipped a bunch of them, and really like them all a lot.
austinado16 is offline
post #15 of 37 Old 01-20-2016, 05:00 PM
Jeff
Well the JX75 is going to it's new Home with KDL here from the Forum.
Enjoy it Karl, it's been a fantastic mower for me and I'm sure you'll love it once Spring arrives, it does everything very well.
If anyone here is interested in the 14SB hit me up either by PM on the Forum or e-mail me at [email protected]
Jeff
JCturboT is offline
