Garden Tractor clutch slips during pull - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
The Pulling Club Puller Builds and Discussions
post #1 of 4 Old 09-04-2018, 01:43 PM Thread Starter
I pulled with my garden tractor and the first hook I pulled in 1st gear and had enough power but lost tire traction which I was glad about because everyone there said I’d never make it with an 8hp engine, pulled 92 feet. So the next hook I tried 2nd gear and made it a little farther about 105 feet but when the weight on the sled reached a certain point, tires stopped moving and tractor stopped dead in its tracks. I have reason to believe my clutch plates are slipping on the drive shaft. I had this issue during a practice pull and tightened the clutch spring to almost nothing between the spring when engaged to ensure enough tension. Is there anything I can add or do to get my traction on the clutch faces? Any help would be great!
It’s a bolens 853 model
bombboy90 is offline
post #2 of 4 Old 09-04-2018, 06:25 PM
Re: Garden Tractor clutch slips during pull
As I recall the 853 has large & small clutch discs, I never did any "pulling" but back in the day those clutches never slipped. Could you put stronger spring on the drive shaft ? My two cents
rjmartinny is offline
post #3 of 4 Old 09-04-2018, 10:13 PM Thread Starter
I was told that by another puller and tractor enuthsiest. I thought of just putting washers in line with it to push it more forward but I have the spring nearly smashed as it is. I may have to find the stiffer spring but the pulling seasons almost over this year, gives me time to locate one. Thanks for your input!!
post #4 of 4 Old 10-11-2019, 09:31 PM
http://gardentractorpullingtips.com/clutch.htm
Check out that page, has some good info
Sent from my SM-N960U using Tapatalk
Whitey1983 is online now
