Need help picking transmission! - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
The Pulling Club Puller Builds and Discussions
post #1 of 1 Old 07-22-2018, 02:35 PM Thread Starter
Hey guys. Im building a kart out of two mower frames welded together. The rar half was set up for a vertical shaft engine, and trans with a tension clutched belt driving it from underneath, and a chain drive out the side.
I see various peerless and fake peerless units called pro grade which fit this description. But i have no idea if the clones are any good, wether i should get 3, 4, or 5 gears, or how much power each is rated for or rpms.
Most vauglely list what engines are likely to be driving it. 8-12hp give or take. I want to give it at least 14 from this kawasaki fc420v i have from the broken dixon i used for the front frame rails.
Then my other question is, i want this to go pretty fast, and also to be cruising at low rpm in high gear so i dont always run out of fuel. I already doubled the tire circumfrence. But do i gear up the trans, and spin it faster, or gear up the axle, and put more load on the small looking output most have. Maybe split the difference?
KeeganJohnson92 is offline
