Ford Tractor Specifications 1939-1962 - Page 2 - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #16 of 23 Old 10-09-2008, 03:59 PM
farmer dan's Avatar
Re: Ford Tractor Specifications 1939-1962
If I read this right the Nebraska tractor test says the drawbar power should be 16.31 hp. I got tons of stuff from the Universatiy of Nebraska on the 9N if you want it.
Name:	test 339 page 3.jpg
USMC/DAV
farmer dan is offline
post #17 of 23 Old 10-10-2008, 05:14 AM
Retired MTF Admin
Ken N Tx's Avatar
Dan, which tractor is the data for?? 9N-2N-8N-NAA ???
Ken N Tx is offline
post #18 of 23 Old 10-10-2008, 09:22 PM
farmer dan's Avatar
the tractor tested was 9N12840 the test dates are April 9 to 18, 1940.
They have the tractor model listed as "Ford-Ferguson System 9N"
USMC/DAV
post #19 of 23 Old 12-02-2008, 08:37 PM
Way cool! Thanks for the info.
cowboydave is offline
post #20 of 23 Old 01-13-2009, 08:32 PM
That's really handy, especially the engine/trans combos in the NAA series. That's where the line up gets complicated. The only discrepancy I noticed was the engine size and PTO rating. According to the Ford 9N/2N Service manual, the engine size is 119.7 cubic inches. The horsepower rating was23.87 (maximum belt) and the "rated belt" is 20.29 (85% of maximum). The maximum drawbar rating was 16.90 (without the 3 point hitch) and the rated drawbar hp was 12.68 (75% of maximum).
The 8N should also be 119.7 cubes, since it used the same bore and stroke, but it used a higher compression ratio for slightly higher hp.
The manual also lists the PTO as "509 rpm at an engine speed of 1400 rpm" and a shaft size of one and one eighth inches.
Anyway, thanks for putting all that together. The tractor lineup was simple until Ford discovered that one size really didn't fit everyone after all.
jeff64 is offline
post #21 of 23 Old 01-13-2009, 08:44 PM
Leo E Hanus
lhanus's Avatar
Great work Steve. Congratulations to a fellow Texan.
lhanus is offline
post #22 of 23 Old 04-02-2009, 11:44 AM
Paul J's Avatar
Being new to the forum, I want to thank you Steve for the information. Great information! Now I have to check the serial number to see if my 1955 Ford is a 630 or 640.
Paul J is offline
post #23 of 23 Old 04-18-2010, 11:17 PM
awesome info. i've had my 9n for a little over a year and it's great. i think i might have to adjust the clutch though
tripleh87 is offline
