Three Filters on an N - Page 2 - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #16 of 25 Old 01-04-2010, 02:09 PM
Retired - Veteran Mod
Steve (Magnolia, TX)'s Avatar
Send a message via MSN to Steve (Magnolia, TX)
Re: Three Filters on an N
Originally Posted by met828 View Post
the carb filter thats just were the line comes in at the carb right
Correct. That's the brass elbow where the steel fuel line enters the cast iron carburetor.
post #17 of 25 Old 01-07-2010, 09:54 PM
Hey Met828
That would be Right.
It is right at your Carb. Sometimes I have seen the screen come loose from the elbow. That is the Last Chance Filter.
Getter-Done is offline
post #18 of 25 Old 01-08-2010, 08:53 AM
met828's Avatar
ill have to check em all i had my 47 running good now she wants to run with a lil choke just happened out of the blue cleaned carb and still the same so im thinking shes starving for fuel due to clog somewhere it sat for 2yrs before i got her ill have to post pic its got grove fenders on her but there homemade goofiest looking 8n ive seen
met828 is offline
post #19 of 25 Old 01-08-2010, 08:57 AM Thread Starter
Retired MTF Admin
Ken N Tx's Avatar
...start a new Thread and show us what you got..
Ken N Tx is offline
post #20 of 25 Old 04-04-2010, 10:21 PM
Ok, so some of us aren't so bright...
looking at the filter in the tank on top the sediment bowl, like you all said, it's open at the top and its only there to catch stuff drifting about at the bottom of the tank and keep it form sliding down into the sediment bulb.
OK. so where does the fuel get into the sediment bowl in the first place? via the brass tube that sticks up or through the filter and down around the brass tube? Or is the former 'normal operation' and the latter 'reserve'?
help us newbies figger it out.
thanks!
Northeast Ohio
Cub 782
TO-30 with a Pippin backhoe and a Wagner Loader
NAA with Davis loader
whf4 is offline
post #21 of 25 Old 04-04-2010, 11:24 PM
thanks!
The main fuel, two turns open on valve, goes thru the long tupe into the bowl and the reserve goes into the bowl at the bottom of the long tube down inside the screen in tank.
Bob G is offline
post #22 of 25 Old 04-04-2010, 11:45 PM
Thanks!
So the screen in the tank really just functions for the reserve?
Northeast Ohio
Cub 782
whf4 is offline
post #23 of 25 Old 04-04-2010, 11:51 PM
Thanks!
That is how I see it. I had the long tube plug on my 8N last year, I was bush hogging and got the gas stired up a bit i guess.
Bob G is offline
post #24 of 25 Old 04-11-2011, 08:43 AM
Old Iron 1%er
Originally Posted by iowa View Post
isn't there a filter
attached to the
oil plug used to drain
the engine oil?
iowa
it looks like a steel mesh 'pop can' with the oil drain cap as the base of the 'pop can' with no top. Many have been lost over the years; its purpose is to prevent larger particles from getting up into and damaging the oil pump (then I think the oil goes to the filter, and onto the engine).
AMCJavelin74 is offline
post #25 of 25 Old 04-11-2011, 09:52 AM
From the pump the oil goes to the oil galley and pressure relief valve. part of the oil from the brass fitting at the back of the engine goes to the filter and then to the gov housing. there is a good oil flow dia in fo-4.Only part of the oil is filtered. oil flows directly from the pump to the main and rod bearings with no filtering.
Bob G is offline
Oil Filter Brands Mkos1980 Lubrication and Filters 25 04-12-2007 08:23 AM
Fluids and filters for an H14 CJT Bolens Forum 1 01-21-2007 06:53 PM
oil filters: where do you get them? simple_john Backyard Round Table - L & G Tractor Related Topics 16 10-31-2006 10:05 PM
Filters neolady Bolens Forum 7 04-20-2006 03:52 PM
Cub Cadet or other Brands of Filters Mr Hoss Cub Cadet Forum 3 05-15-2005 03:10 AM
