x7 Weights & Measures for Tractors/Attachments - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 15 Old 02-17-2013, 10:01 PM Thread Starter
MTF mile high club member
Diesel Powered's Avatar
There's been a few threads lately talking about weight, weight transfer, and dimensions of tractors with certain attachments; hopefully this can be a go-to source of info for various x7 tractors when people need info for sizing a trailer, building a shed, etc. Feel free to add any and all info you might have!
I spent some time at the local big truck scale today to get things started. The following is info from an x748 MFWD with a 45 loader, click-n-go weight bracket, full tank of fuel, a 250 lb operator (when noted), and six 42 pound suitcase weights hanging out back. This particular scale moved in 20 lb increments; some of these I just measured the front axle for differences once I did the original test, then did the math (that's why some are 10 lb increments).
In order to find a good average load (towards the high end of an average load for most people), I scooped up a full bucket of 1" clean limestone and weighed it at roughly 450 lbs; since that's a potentially messy load on a scale, I substituted 11 suitcase weights in the bucket (42 lbs each) which comes to 462 lbs.
This is the amount of gravel (hard to tell, but it's basically level across)...
The tractor looked like a toy on that big scale...
Loader alone: 480 lbs
Tractor alone: 1180 lbs
Tractor alone w/ operator (no rear suitcase weights):
Front axle: 610 lbs
Rear axle: 820 lbs
Total: 1430 lbs
Tractor alone w/ operator (6 rear suitcase weights):
Front axle: 550 lbs
Rear axle: 1130 lbs
Total: 1680 lbs
Tractor alone w/o operator (6 rear suitcase weights):
Front axle: 510 lbs
Rear axle: 920 lbs
Total: 1430 lbs
Tractor w/ operator and 45 loader (empty bucket / no rear suitcase weights): 1910 lbs
Front axle w/ bucket ~1" off the ground: 1140 lbs
Front axle w/ bucket ~2' off the ground: 1220 lbs
Front axle w/ bucket at full height: 1140 lbs
Tractor w/ operator and 45 loader (empty bucket / 6 rear suitcase weights): 2160 lbs
Front axle w/ bucket ~1" off the ground: 1060 lbs
Front axle w/ bucket ~2' off the ground: 1100 lbs
Front axle w/ bucket at full height: 1060 lbs
Tractor w/ operator and 45 loader (full bucket / no rear suitcase weights): 2370 lbs
Front axle w/ bucket ~1" off the ground: 1900 lbs
Front axle w/ bucket ~2' off the ground: 2380 lbs
Front axle w/ bucket at full height: Not going to happen.
Tractor w/ operator and 45 loader (full bucket / 6 rear suitcase weights): 2620 lbs
Front axle w/ bucket ~1" off the ground: 1800 lbs
Front axle w/ bucket ~2' off the ground: 1950 lbs
Front axle w/ bucket at full height: 1800 lbs
Hopefully this thread will help some people; there's also some things to be learned from this as far as weight transfer goes (like why the steering isn't very good when you're in float mode with a blade and there's 6 suitcase weights out back.. the front axle is 100 lbs lighter). There's more to come later as time allows and attachments get changed; once again, please add your own info since different people have different attachments/accessories (overall legth, weight if possible, height if applicable (cabs), etc).
2011 JD X748
2004 JD 4410 TLB
Diesel Powered is offline
post #2 of 15 Old 02-19-2013, 08:20 PM
4K Poster!!!!
8086bruce's Avatar
Re: x7 Weights & Measures for Tractors/Attachments
Great info DP!
John Deere X758
54HC deck
54" Quick hitch blade
47" Quick hitch blower with side plates
JD Weather Enclosure
8086bruce is offline
post #3 of 15 Old 02-20-2013, 07:06 PM
Administrator
Mike X485's Avatar
DP, Thanks for taking the time to put this together.
JOHN DEERE X748
Mike X485 is offline
post #4 of 15 Old 02-20-2013, 07:51 PM
Jerry
MNvet's Avatar
Ditto!!!
John Deere X748 and assorted attachments
MNvet is offline
post #5 of 15 Old 02-20-2013, 08:03 PM
GO TIGERS!
Hostaman's Avatar
Any thoughts of making this into a Sticky?
As we have all asked questions regarding ballast and it's effect on weight transfer this helps demonstrate what Tudor and DP keep trying to explain.
Thank you for the information, I bet it was a lot of fun gathering it and playing with the big scale.
X728, X729
54" Deck w/BM20827 Mulch Kit, 45 Loader, JD BM23882 Cat 1 3PH, JD LPHDC18JD 18 CuFt Cart, JD LP22862 25 Gallon Sprayer, JD LPPA48JD 48" Core Aerator, JD LP25001 3-Point Receiver Hitch, JD BM17972 50 lb. Cast Wheel Weights, JD BM22725 Wheel Spacers, Custom Heavy Hitch, TOMBSTONE* Ballast Slab, Eight Suitcase Weights, Fluid Filled HDAPs on Stock Wheels, Turfs on SE Wheels, SE Seat, Brush Guard, Click-N-Go Weight Bracket (Modified to hold eight suitcase weights)
*named by PA318Guy
Hostaman is offline
post #6 of 15 Old 02-20-2013, 09:10 PM
Catmancoop's Avatar
Thanks for going through this analysis, DP! Very interesting.
John Deere X495
Proud member of the red cap club!
62C, HDAP's, 45 Loader, 647 tiller, Cat1 3PT Hitch, PTO, iMatch coupler, 8 suitcase weights,
iMatch Hydraulic Tilt Dump MCS/PowerFlow,
iMatch Heavy Hitch.
A wonderful wife that puts up with my addiction
She calls me "the man in green that works for yellow"
Catmancoop is offline
post #7 of 15 Old 02-20-2013, 09:21 PM
Outstanding project! This is great!
Now, where did you get 17 suitcase weights to run this study???
2012 X748 with R4 tires, 3pt hitch and rear PTO. 54" blade, 45 loader, 60" 7-iron deck, 60" mid blade, 647 tiller , 60" rear blade, 60" landscape rake, home built "heavy hitch" for 8 suitcase weights, 75lb starter weights. Cyclone Rake XL with dual wheels, estate vacuum, and power unloader options - god how I love that attachment!!!
2012 X749 "Winter machine" with R1 tires, Curtis hard cab (custom heat & AC!), 54" blower, 54” rubber edge blade, 52" broom, 50lb rear wheel weights.
Tmsoko is offline
post #8 of 15 Old 02-20-2013, 11:23 PM Thread Starter
Thanks, fellas. More to come as time allows.
They've accumulated from good deals over the years; I've been trying to pass the good deals along to some locals lately so somebody else can get some good use out of 'em, but no such luck yet. The last count was 26, but I only regularly use ~15.
I did find out that 19 weights will fit side-by-side in the loader bucket, but the loader says "get lost" when you try to lift 'em.
2011 JD X748
2004 JD 4410 TLB
post #9 of 15 Old 02-21-2013, 04:44 AM
20,000 Posts & Climbing
Yah got the wrong colour tractor for that kinda work! Try red!
Great thread DP!! It's nice to have definitive answers to some of the weight questions, instead of generalized ballpark figures.
I just stuck it! That should save us some typing in the future.
TUDOR is online now
post #10 of 15 Old 02-22-2013, 02:02 PM
POENY's Avatar
Great info DP! This has definitely been a challenge for some to explain and others to understand (or even believe).
I really like the Tractor & Operator #s compared to the Tractor & Rear Weights #s. You and your weights are the same (well you have much more value than they do) so it is interesting to see how 100# of weight transfers from the front axle to the rear axle as you move that 250# from the seat (above the rear axle) back to where the suitcase weights are located. The same total weight but a different balance front to back based on the leverage of that 250#. Guys like Rob and Roy with their weight even further out back on a 3pt hitch would see this difference more exaggerated.
I took your info and put it into a spreadsheet to help me see it and thought I would share it.
for taking the time to put this together!
Name:	Diesel Power's X748 weight info5.jpg
2007 John Deere X748 w/SEat - aka Herman
John Deere 54" Snowblower, 54" Snowblower chute rotation modification, WE - Weather Enclosure, lights, & propane heater,
62C MMM, HDAPs w/ Rim Guard, 4 Suitcase weights, Hitch w/ platform & 16 gallon sprayer, Johnny Bucket Sr
POENY is offline
post #11 of 15 Old 02-22-2013, 06:42 PM Thread Starter
Thanks. Good idea on the spreadsheet.
2011 JD X748
2004 JD 4410 TLB
post #12 of 15 Old 02-22-2013, 07:03 PM
Diesel Powered and everybody else, is there any serious objection to moving this thread to the Back Yard Round Table where more folks will get a look at it? Many members don't spend a lot of time outside their own brands or interests and could easily miss this information tucked away in the JD sticky section.
This is a great resource for the effect of weights on balances for any colour of FEL and POENY's spread sheet really makes it easy to understand what is going on.
TUDOR is online now
post #13 of 15 Old 02-22-2013, 07:23 PM
Administrator
Mike X485's Avatar
Bob, I understand what you would like to do, but if you go back and read the first couple of lines of this thread, DP wanted to start a thread with all kinds of dimensions regarding the X700 series. He started with the weight issue and hopefully others will contribute with lengths, heights and widths with different attachments.
IMO it should stay on the John Deere Forum.
JOHN DEERE X748
post #14 of 15 Old 02-22-2013, 09:33 PM Thread Starter
Ditto to what Mike said, but what about starting a more universal thread like "understanding weight transfer" or something along those lines? I'd be willing to contribute my scale data if that helps.
2011 JD X748
2004 JD 4410 TLB
post #15 of 15 Old 02-23-2013, 03:20 PM
Understood. That's why I asked.
Thank you. I'll do it that way later tonight with a link back to this thread.
TUDOR is online now
