Troy bilt 7hp horse tiller Bar 1034 Adjustment? - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 3 Old 06-14-2019, 02:33 PM Thread Starter
Hi. Troy bilt belts appear to big. Engine guide bar p/n: 1034 feel out and was replaced. I have not found an adjustment for these 2 bars.
My horse tiller is now stretching "troy bilt" belts since replacing the right bar pn 1034. The bars have a grove which looks like an adjustment, but each bar is bolted at the top. When a new belt is installed and ajusted, the belt is snug and roller stays in the required area on the ramp. Tiller moves and shifts as usual. When tines are engaged the belt slips and the belt becomes loose. It appeared the tine attachment is causing to much drag. The tines and shaft are clear of trash, the tine input pulley turns easily with the engine drive in neutral and the tines engaged, tInes turn. I checked the engine pulley per the manual. I loosened then tightened the pulley bolt.
I am able to till but I must push down on the clutch lever which raises the engine enough to tighten the belt.
Each belt manufacturer states their belt is for troy bilt. Some of my belts are marked "Troy bilt p/n: 9245". And indicate in the packaging to be 1/2" x 22" v-belt.
Any suggestions are appriciated.
Thanks you
Ron
Ronbeau is offline
post #2 of 3 Old 06-14-2019, 11:29 PM
Re: Troy bilt 7hp horse tiller Bar 1034 Adjustment?
I am totally new to Troy Bilt Horse tillers but I have been reading a lot and researching them. I just bought one that I will be asking some questions about and posting some pictures. I have a Kohler K161T 7hp engine powered Troy Bilt Horse.
When you say the "clutch lever" are you referring to the forward/neutral/reverse lever? Is the clutch pawl spring old, weak and stretched out? I read that a weak pawl spring will cause the lever to pop out or not stay in forward.
Tractor Beam is offline
post #3 of 3 Old 06-18-2019, 08:29 PM
Dirt Digger
chzuck's Avatar
Have you followed the adjustment procedure outlined in the owners manual? The two bars you are referring to, are they the ones the motor frame slides up and down on. If so, those rods have a counter-bored hole that the bolt on the side should be seated into.
Charlie H Zuck
www.zucksrototillers.com
There is only one ROTOTILLER.
My YouTube Channel
chzuck is offline
