646 tires - Page 2 - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #16 of 21 Old 09-16-2019, 09:36 PM Thread Starter
shgreen1's Avatar
Re: 646 tires
Originally Posted by sddunt View Post
I've had AMERICAN FARMER TRACTION IMPLEMENT I-3 7.60 x 15's on my 646 and they are good tires.. I wanted to go to the 160 pound combine weights, so I put 16 inch rims from a 446 on my tractor and used 7-16 Trupowers:
To follow up on tires for the 646 (or what I am running this season).
With the loader we are always looking for more ballast. it's like an obsession.. The little squirt can lift more than it can move.. AKA it lifts the rear wheels off the ground..
So, I picked up a set of 'Combine' weights that tip the scales at 160 pounds each. Which would take 4 - Case D 10's weights in each side to come close. and of course you'd have to find the D-10's and pay $$$$ for them.
BUT, the combine weights won't fit in the 15" rims on the loaders (there is apparently a 10 inch wide 15 inch rim that they WILL fit into) but for the standard oem 7 x 15" rims the 160 pound weights don't fit. The weights were designed for and DO fit 16 in rims, like the 4xx and 40xx tractors have.. Hmm, I have a 446 that I am scrapping. Does anyone make a tire that I could put on a 16 inch 446 rim and still fit under the fenders on the loader?
The size chart from the Carlisle catalog has some interesting data in it.. The 7 -16 tires stand almost 2 inches shorter than the 8 - 16 tires. And at 29 inches the Carlisle 7 - 16's are actually shorter than the "American Farmer" 7.60 x 15:
Carlisle 7 -16 on 8" wide 16" rim from 446 on the right. American Farmer 7.60 x 15 on the 646's original 7" wide by 15 rims on the left. The 16" tire is actually a 1/2 to 1 inch shorter than the 15".
Width wise the lugs on the Carlisle measure just a tag short of 7" wide while the American Farmer measure 7 1/4" And the Carlisle has deeper lugs but fewer of them.
I was tempted to go the 7-16 TruPower route, but was concerned that the increased diameter wouldn't fit under the fenders, the extra weight would be nice.
Anyone know how much the stock Case cast iron wheel weights weigh?
shgreen1 is offline
post #17 of 21 Old 09-16-2019, 09:37 PM
Hemlock Case Guy
The tires need to have a load rating of around 1,000 lbs each.
ssmewing is offline
post #18 of 21 Old 09-17-2019, 10:14 AM
Re: 646 tires
Steve you pictures are not showing up. It looks like they are on Google? All I see is a circle with a line through it.
Originally Posted by ssmewing View Post
Here are my nearly bald tires. That does not matter once the 2 link chains are on. Not only is that cheaper than the awesome looking treads I could buy, but did not have the money for, but you cannot beat chains for year-round traction. I have some logger chains, meaning big chain links that are NOS I found on CL.
The guy I bought the chains from had a couple of Steiner tractors with the dump bed. I had one but lost it in the divorce. Those things are awesome. If I still had it I never would have become a Case guy. When You can push wet heavy snow with a 60" angled blade at full speed with bald tires and no chains, you are in tractor heaven. I had pretty much every attachment except for the front brush attachment and brush hog.
1973 Case 646 (w/Custom Power Steering)
1968 Case 155
1958 JI Case 310 Terratrac Crawler Loader
sddunt is offline
post #19 of 21 Old 09-17-2019, 10:18 AM
Re: 646 tires
Wheel Weight Options document attached
1968 Case 155
sddunt is offline
post #20 of 21 Old 09-17-2019, 10:43 AM
Hemlock Case Guy
Re: 646 tires
How is it this time?
Name:	29x12.50-15 tires.jpg
ID:	2396435   Click image for larger version
Name:	wheel spacers.jpg
ssmewing is offline
post #21 of 21 Old 09-17-2019, 10:57 AM
Re: 646 tires
perfect.. thanks.. Those are some SERIOUS spacers.
1968 Case 155
sddunt is offline
