Selector Valve and 3pt Install - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 12 Old 04-08-2013, 06:32 AM Thread Starter
BOSS351C's Avatar
Since the threat of snow is mostly gone here now, I decided to plumb in my selector valve so i could mount my homemade three point hitch. I finished the three point to sleeve adapter earlier in the week. For the selector valve I chose to mount it where the flow control would normally go since I have no intention of getting on of those. I also set the valve up to have a lever instead of the standard push/pull knob. This setup puts the control right next to the implement lift control for quick changes between lift circuits with minimal movement. I used 5/16 steel hydraulic tubing for all of the lines and put 1/4" quick connects at the rear of the tractor so I can easily remove the 3pt if I need to. I only had to drill one extra hole in the tractor to mount the valve bracket and trim a little of the front of the foot rest, but I have 4016 fenders and foot rests on an early '79 short wheelbase tractor.
Tried to till, first three passes were good, fourth pass turned to clay soup. Still got the tractor out on it's own though. I love this thing!
Name:	Selector Valve (2).jpg
ID:	254391   Click image for larger version
Name:	Selector Valve.jpg
ID:	254392   Click image for larger version
ID:	254393   Click image for larger version
Name:	Sleeve Hitch Adapter (4).jpg
Kubota BX2660 w/ FEL & 60" MMM
BOSS351C is offline
post #2 of 12 Old 04-08-2013, 03:33 PM
RestMyCase's Avatar
Re: Selector Valve and 3pt Install
Very nice work on everything. Thank's for sharing it with us ...
RestMyCase is offline
post #3 of 12 Old 04-08-2013, 07:42 PM
thats looking mighety cool to me,good job-good luck,Kyle
bolenscase is offline
post #4 of 12 Old 04-08-2013, 07:53 PM
smokehouseman's Avatar
Could you list more info on the selector valve I'd be interested in doing something like this on my 4016. I like the way this set up looks.
smokehouseman is offline
post #5 of 12 Old 04-09-2013, 06:33 AM Thread Starter
BOSS351C's Avatar
Thanks guys. I parked the tractor in the shop Sunday afternoon with the tiller raised just to see if I had any leaks. It is still all the way up with no drips this morning.
I used used this Prince holding valve from Surplus Center (they were out of the 3/8 port so I used the 1/2 port model, but this is the one I would have used):
http://www.surpluscenter.com/item.as...name=hydraulic
Prince sells a handle kit for this valve but I could not find one anywhere so I made my own. I wanted a lever instead of the knob for easy of changing the circuit. Leveling dirt and gravel with the front blade and back blade will be quick and easy now.
I bought all of the fittings from Discount Hydraulic hose.com. They even sell the run tee's as used OEM on the 3pts. http://www.discounthydraulichose.com/product_p/6602.htm
All of the lift circuit fittings are -5 JIC (5/16"). In the manuals sticky here are the oem Case instructions for how to plumb the selector valve. The hydrualic tubing came from Hose and Fittings.com. http://shop.hoseandfittings.com/cata...312X.035W.html
They will cut and ship UPS which most other online suppliers won't. I have also bought it it other sizes from the local Parker Store for much less $ but I can't get there when they are open anymore with my new job.
I bought a Parker flaring tool specifically for hydrualic tubing from an airplane supply site that I can't remember now. It has been one of my favorite tool purchases. Here is a random youtube video that shows how it works pretty well:
http://www.youtube.com/watch?v=gTGP_TXZQqA
They did leave out the fact that there is a built in stop that sets the tubing height in the dies so you always get perfect flairs. It will flair tubing from 1/8 to 3/4.
BOSS351C is offline
post #6 of 12 Old 04-09-2013, 09:46 PM
Thumbs up Re: Selector Valve and 3pt Install
great post- thanks-this will come in real handy-Kyle,
post #7 of 12 Old 04-10-2013, 03:39 AM
GET TOUGH GET A CASE!
Mjoe7's Avatar
Very nice work! Thanks for sharing.
Mike In the beginning God created...
See my tractors in action on youtube! User Mjoe7. http://www.youtube.com/user/mjoe7
Mjoe7 is offline
post #8 of 12 Old 04-10-2013, 05:40 AM
longman's Avatar
Good stuff here.
Nice job and thanks for the info.
longman is offline
Old 04-10-2013, 05:17 PM
BAfton
This message has been deleted by Ingersoll444.
post #9 of 12 Old 04-14-2013, 08:45 AM
Lawnmower Collector
case13's Avatar
Very nice!
Sent from the MTF Free App
case13 is offline
post #10 of 12 Old 01-26-2019, 11:19 AM
donkman's Avatar
Nice job, Thanks
donkman is offline
post #11 of 12 Old 01-27-2019, 07:21 AM
Boss
You run the tiller with out front weights?
G.Paul is offline
post #12 of 12 Old 03-30-2019, 08:05 AM
David Barkey's Avatar
Excellent workmanship. Very well done .
Dave
David Barkey is offline
