Case 446 1986 Travel Control Valve overhaul - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 4 Old 08-27-2019, 09:58 PM Thread Starter
Clode1985
Hi, I have a leaky control valve and decided to replace all of the o rings in it. Took it appart and only found 2 of them, on the end where the linkage connect to. However I notice there is a wider groove on the cap/spring side. Looking at the diagram doesnt show anything. Is this the it's done or is there a part missing?
Claude St-Laurent is offline
post #2 of 4 Old 08-28-2019, 12:22 PM Thread Starter
Clode1985
Re: Case 446 1986 Travel Control Valve overhaul
Here's some pics of my Valve, and the valve diagram. The diagram doesn't show any seals on the cap side, but how do I prevent oil to go in the cap?
ID:	2393541   Click image for larger version
ID:	2393543   Click image for larger version
ID:	2393545   Click image for larger version
Name:	Hydraulic diagram.png
post #3 of 4 Old 08-29-2019, 09:23 AM
Here is a dealer that can help you with a rebuild kit ask for Bill. 608-220-7062
G.Paul is offline
post #4 of 4 Old 08-29-2019, 10:17 AM
One needs to look at the Diagram AND the parts listing, Especially the "REQ'D" column. where is shows that 4 of the O ring A7982 are required for each valve. With only 2 spools that makes for 2 Orings per spool, one at each end..
Later parts manuals for 4xxx tractors and the like do show 4 orings on the diagram as well.
1973 Case 646 (w/Custom Power Steering)
1968 Case 155
1958 JI Case 310 Terratrac Crawler Loader
sddunt is offline
