646 questions - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 18 Old 05-31-2019, 07:33 AM Thread Starter
646 questions
I have an appointment to look at a 646 tomorrow morning. He wants $1500 for it. Says he put a new hydraulic pump in a few years ago and hydraulics are strong. Said the engine is "tired" and is hard to start but runs fine once it does, I didn't ask about smoking, and the travel pedal does not come back up on its own but has to be pulled up. His diagnosis was that it is a broken spring inside a valve. Maybe a tear or two in the seat. It's 3 hours away and then I would have to rent a truck and a car carrier to bring it home, about $200 plus gas. So a total of 12+ hours of my time and $1750 +or-. He said he had another inquiry who was an "enthusiast" but could not make it this weekend and he opted not to hold it that long. We have a fairly large garden and put 8-10 yards of manure on it every year which I currently shovel into a small garden wagon pulled by a lawn tractor, and at 70 YO, it is not getting easier. I already have a decent condition 448 that I use to drag the driveway and pull small logs out of the woods and probably could sell that to defray some of the cost. Would appreciate any input or advice. Thanks, Larry
Name:	646 tractor.jpg
larrypac is offline
post #2 of 18 Old 05-31-2019, 05:01 PM
Re: 646 questions
'Tired' engine thats's hard to start probably points to low compression. That said, the price is attractive. Even with some major engine work you should be into it about $2500 or so, assuming you are your own mechanic. Usually rings and gaskets will bring an older Onan back to usable condition.
But, as you know, one can't be sure until it's disassembled and clean on your work bench.
antiqueetc is offline
post #3 of 18 Old 05-31-2019, 05:17 PM Thread Starter
Re: 646 questions
Originally Posted by antiqueetc View Post
'Tired' engine that's hard to start probably points to low compression. That said, the price is attractive. Even with some major engine work you should be into it about $2500 or so, assuming you are your own mechanic. Usually rings and gaskets will bring an older Onan back to usable condition.
What would rings cost approximately and how much of a job is it. I am familiar with tools and procedures. Got rid of my ring compressor years ago thinking I would never use it again. Larry
larrypac is offline
post #4 of 18 Old 05-31-2019, 07:59 PM Thread Starter
Re: 646 questions
Can anyone weigh in about the travel pedal problem? Is the spring inside the valve and if so, could you substitute an external spring somehow? Thanks, Larry
larrypac is offline
post #5 of 18 Old 05-31-2019, 08:03 PM
mikgran's Avatar
Re: 646 questions
I saw that on our local CL. I wouldn’t wait long.
2004 X485- 54 deck, 47 blower
1977 210
1970 110H
1991 Ariens YT12H w/bagger
1986 Kubota B7200HST
mikgran is online now
post #6 of 18 Old 05-31-2019, 08:19 PM Thread Starter
Re: 646 questions
I'm going to look first thing tomorrow morning but am hoping to gather as much information as possible before I go.
larrypac is offline
post #7 of 18 Old 06-01-2019, 07:32 AM
Re: 646 questions
There is an external spring that pulls the travel pedal back up. But its more likely the Banana plate is worn out and that's why the pedal is not returning.
the un official, how to Evaluate a CCI Loader is here: https://casecoltingersoll.com/showth...l=1#post679009
That tractor will fit in a Uhaul "5x9 Utility Trailer Rental with Ramp" and that's one of the only open trailers they will let you rent one way. Been there done that.
1973 Case 646 (w/Custom Power Steering)
1968 Case 155
1958 JI Case 310 Terratrac Crawler Loader
sddunt is offline
post #8 of 18 Old 06-01-2019, 05:10 PM Thread Starter
Re: 646 questions
That is exactly the trailer I rented. The guy at the Uhaul said I would have no problem towing it with my 4 cyl Camry but I had reservations to say the least about towing 2400 pounds (1200 for trailer and 1200 for tractor) with a Camry so i drove the 30 minutes to my sons house and borrowed his wife Nissan Xterra which pulled it easily. We have our grand daughter visiting so the Nissan will go back with her tomorrow. I checked the compression with the PO's high end tester and got 125 pis on both sides, so I don't think the engine is particularly tired. pretty sure that the fuel is leaking back down so that if it sits for a week or so it takes a long time to start. It started instantly when I got home. So I'm confident that I can fix that easily. I'm pretty fried right now so i will look into the banana plate issue tomorrow. LP
larrypac is offline
post #9 of 18 Old 06-01-2019, 05:52 PM
mikgran's Avatar
Re: 646 questions
Congratulations! Great find at a great price.
Can’t wait to see more pics.
1977 210
1970 110H
post #10 of 18 Old 06-01-2019, 05:56 PM
mikgran's Avatar
Re: 646 questions
Good call on getting the Nissan. That would have been overworking the Camry, IMO.
1977 210
1970 110H
post #11 of 18 Old 06-01-2019, 10:18 PM
Re: 646 questions
Great find , great deal. You'll love that loader, they have a lot of power.
Gary R C is offline
post #12 of 18 Old 06-03-2019, 10:55 AM
Re: 646 questions
Good move on using the other vehicle. A BASIC 646 tips the scales at 1500 pounds. All decked out with fluid in the tires and rear wheel weights the units can top 2,000 pounds easy.
We usually haul my unit around with an F-150.. We have a flatbed car hauler to put it on. Fun part of that was finding ramps for the trailer that could handle 2,000 pounds.. Bost ATV ramps won't cut it.
Some people have moved these in the bed of a truck.. But its a tight fit and probably need a 3/4 ton truck..
1968 Case 155
sddunt is offline
post #13 of 18 Old 06-04-2019, 07:25 AM Thread Starter
Re: 646 questions
After a few days with the new tractor:
I found a screen door spring that makes the travel pedal usable. Still some play in it but I want to use it for a while before I start working on it. Without any weight in the weight box, it lifted a full bucket of manure without hesitation. The PO said that the hydraulic system had hydraulic oil in it. I did not press him on whether that was an assumption or if he had put it in there but since he replaced the pump, I assume that he put at least some hydraulic fluid in. Is it critical that I replace it with motor oil right away? The engine oil was down below the fill line so i filled it up and tractor smoked when first started after that but has not smoked again. Since the compression is good, I'm not worried about that. It has started quickly every time so I'm convinced that the fuel is leaking back down in the line or maybe a tiny leak out of the bowl after sitting for a long time. That is exactly what my 448 did and a carb and fuel pump rebuild solved the problem. Finally, there is a short tube coming up out of the right side of the blower housing (page 18 of parts manual). It almost seems like there should be some kind of flapper valve over this but nothing in the parts manual that I can see. Any thoughts? And I almost forgot, the hour meter says 294. Obviously no way to know when it was disconnected but still better that if it read 2940. There is a nutted yellow wire behind the sheet metal, is that the wire for the meter? I could not even find the hour gauge in the parts manual. Thanks to all who weighed in with advice and encouragement. LP
larrypac is offline
post #14 of 18 Old 06-04-2019, 08:29 AM
Re: 646 questions
The reason Case and many other specify motor oil in the hydraulic system is because there is a "geo Rotor' hydraulic motor in the system. Most Skid steers also specify motor oil again because of the hydraulic motors in the system. Universal tractor hydraulic fluid is about he same viscosity as 15w - 40, but its missing the '-40" the lubrication package. So running hydraulic oil is causing more wear on the hydraulic drive motor. If someone put RED ATF in there that would be panic time.
I'm not following your reference to tube come out of the blower housing, so I marked up the attached diagram.
Name:	CCK Blower Housing.png
1968 Case 155
sddunt is offline
post #15 of 18 Old 06-04-2019, 08:35 AM Thread Starter
Re: 646 questions
Its the tube (opening) at the top left with "coil" written above it
larrypac is offline
