Electric Snowblower Chute Rotation - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 9 Old 05-14-2019, 10:57 AM Thread Starter
Lawnmower Collector
case13's Avatar
Greetings! This is my first post in a long time as I just purchased a Case 214 after i sold my previoud collection. The unit has hydrualic lift and came with a 44" deck, 38" blower, and a snowplow. Paid $200 and it only had a bad coil! Attached is the only picture i have, muddy because the auction site was muddy. More pictures will follow.
However i plan on doing alot of snowblowing this year trying to make an extra buck and i want to install an electric rotation and angle so here is my question to you guys; What rpm rotation motor should i get? And what size/throw actuator should i get for the angle? Also has any one made an electric angle blade? If so how did it work out? Thanks in advance!
case13 is offline
post #2 of 9 Old 05-14-2019, 03:04 PM
spokes100's Avatar
Re: Electric Snowblower Chute Rotation
I have seen a couple of chute rotators made from electric window motors. Check this website and YouTube.
https://www.snowblowerforum.com/
spokes100 is offline
post #3 of 9 Old 05-14-2019, 03:22 PM
I know Warn makes an electric angling setup for their Provantage plows (and perhaps for other models), but it's not cheap. And I looked at various actuators to rig up to my plow, but the ones that can support 400+ lbs (which I expect my plow to have as a load on it) move very slowly [as in, it would be faster for me to walk to the plow and manually adjust the angle]. But chute angle/rotation don't see those large forces, so you can use lighter-duty, faster actuators...
dave_r is online now
post #4 of 9 Old 05-15-2019, 08:48 AM
These posts on the CCI forum might give you some ideas: https://casecoltingersoll.com/showth...electric+chute
https://casecoltingersoll.com/showth...remote-control
1973 Case 646 (w/Custom Power Steering)
1968 Case 155
1958 JI Case 310 Terratrac Crawler Loader
sddunt is offline
post #5 of 9 Old 05-15-2019, 12:29 PM
Hemlock Case Guy
I use 2 seat motors I got from Surpluscenter.com for $15.95 each. One rotates the other runs the deflector. They are cheap and easy. They sell motor reversing switches or you need DPDT. If that DPDT is over your head, you may struggle with this project.
I know you are going to want pictures. They got lost when photobucket decided to charge for hosting.
To run the deflector up and down you tap the traveler nut through onside at 1/4-20. That gets attached to the chute deflector with a bolt from the inside, a nut that will tighten to that bolt from the outside after you screw the bolt into the traveler nut. The seat motor is attached with a single long bolt in a place where you will get the range of motion you want based on the length of the seat motor travel rod.
For the rotator, weld a loop on the end of the seat motor that is just like the one on the handle. Then mount the seat motor to the lift bar using a hardware ubolt and bracket.
Clear as mud?
S
ssmewing is offline
post #6 of 9 Old 05-15-2019, 03:26 PM
Makes total sense to me old buddy, but I'm also the guy that added power steering to Case 646 loader tractor..
A little light reading for you.. :-)
https://monarch14.blogspot.com/2019/...-case-646.html
1968 Case 155
sddunt is offline
post #7 of 9 Old 05-15-2019, 08:40 PM
Hemlock Case Guy
I will be doing the same but different. I am going to use the steering quickener. I had a chance to try one installed on a 4016. It was amazingly easy to steer. And, if it can fit in the tower of a 4 digit tractor, it can fit in a 646. Before that, I had not seen a steering quickener in person. They are smaller than I thought they would be.
I have a 75 646 that needs a complete rebuild. But, it is a good tractor overall. The Onan is certainly tired. But, I like to run fresh engines anyway. None of my tractors take oil before it needs to be changed.
On topic, I posted some pictures of the deflector setup I have on Facebook in a Case Colt Ingersoll group. I have no idea how to find it, though.
ssmewing is offline
post #8 of 9 Old 05-19-2019, 03:18 PM
case13 - Here is a link to the motor I used on my M84 Snowcaster for chute rotation: https://www.sciplus.com/car-seat-12v...-motor-49248-p
I've included a pdf file of a chart I made up to help me decide what rpm motor I wanted:
Here are pics of the caster with the seat motor installed using a bracket I made to support it:
Name:	ChuteRotation Motor and Bracket (1) - Copy.jpg
ID:	2377281   Click image for larger version
Name:	ChuteRotation Motor and Bracket (2) - Copy.jpg
ID:	2377283   Click image for larger version
Name:	ChuteRotation Motor and Bracket (3) - Copy.jpg
ID:	2377285   Click image for larger version
Name:	Chute Rotator Motor (1).jpg
BAfton is offline
post #9 of 9 Old 06-04-2019, 07:16 PM Thread Starter
Lawnmower Collector
case13's Avatar
That is really useful! Thank you very much!
Sent from my VS996 using Tapatalk
case13 is offline
CCR2000 Chute Rotation Mod Yard Nazi Snow Removal Equipment 5 12-05-2018 08:37 AM
47 Snowblower chute mod (orbit motor drive) I.P.Yellow John Deere Forum 19 11-18-2018 09:46 PM
Snowblower chute rotator doesn't, in one direction Tom1528 Massey Ferguson 7 05-02-2013 04:33 PM
Replacement metal chute for 44" snowblower attachment? TimmyC John Deere Forum 19 01-17-2013 02:19 PM
