Friction disc repair - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 10 Old 05-10-2019, 12:40 PM Thread Starter
I have to replace the friction disc on my 444. The replacement kit I purchased comes with adhesive on the new disc and instructions for the baking procedure to adhere the disc to the clutch pulley. A Case service bulletin from the 70's I found states that good results were reported from dealers by using contact cement instead of the baking procedure. Contact cement sounds a lot simpler and faster. Has anyone tried contact cement and how did it work out? Any other comments about disc replacement will be gratefully received since this is my first clutch fix.
saltspringer is offline
post #2 of 10 Old 05-10-2019, 12:58 PM
Re: Friction disc repair
The baking works best. Contact will work, but, it is not as heat resistant as the factory adhesive. I've done it with success, but I don't think I'll chance it again.
antiqueetc is offline
post #3 of 10 Old 05-10-2019, 02:38 PM
Set your wife's oven at 400 degree for 30 minutes (make sure she is not home or your in trouble) and backe it on also the pad needs to clamped with a round plate. Contact cement is not so heat resistant
G.Paul is offline
post #4 of 10 Old 05-11-2019, 11:14 AM
Hemlock Case Guy
That bulletin was then and things have changed. What you more need to focus on is the fact that you need to clamp the disc at 70 foot pounds. That is a lot and that is important.
ssmewing is offline
post #5 of 10 Old 05-11-2019, 01:13 PM
It is 400 degree for 30 minutes at 80 ft pounds torque according to the manual
G.Paul is offline
post #6 of 10 Old 05-11-2019, 07:54 PM
"things have changed", reminded me. When I did one with Contact Cement, it was solvent based. Some of the 'eco friendly' stuff is now not solvent based. I wouldn't use that stuff on anything! Tried it once on some cabinet tops, it's worthless!
post #7 of 10 Old 05-11-2019, 11:14 PM Thread Starter
Thanks all for the feedback. Looks like I'll be smelling up the kitchen.
post #8 of 10 Old 05-12-2019, 06:35 AM
Hemlock Case Guy
If you spray and wipe your pulley with brake cleaner and clean it up well, which you need to do anyway, it should not create much odor. I would especially make sure the mating surface has no remnant of past adhesive or disk on it. I use the wire wheel on my bench grinder.
Oh, there is a bearing in it that you need to remove. You need to replace all 3 bearings while this is all going on. It will quite the operation not to mention when they really go bad, they wipe out expensive other pieces.
The wavy washers cost a little more and it would be good to replace them. But, not everyone does that. They are crucial. They are half of your friction pressure. The lever closes the gap via the cams. The wavy washers push back from the other side.
ssmewing is offline
post #9 of 10 Old 05-12-2019, 10:37 AM
Saltspringer
I live in SW Michigan if your not to far away I can repair the clutch for you and resurface the mating plate while you wait
G.Paul is offline
post #10 of 10 Old 05-12-2019, 11:05 AM Thread Starter
C
Originally Posted by g.paul View Post
saltspringer
i live in sw michigan if your not to far away i can repair the clutch for you and resurface the mating plate while you wait
Ronpage
Lawn-boy Picture Thread Updated 02-07-2019 my_crib_too Walk Behind Mowers 79 02-07-2019 07:53 PM
Amerisun Recalls to Repair Snow Blowers Due to Injury Hazard JP Savage Outdoor Power Equipment Reviews 0 06-09-2018 07:38 AM
Friction Disc Crumbling 2-wheel Tractor Model 47366 earthman Gravely 5 03-08-2018 05:05 PM
anyone use wt lifting weights on disc or aerator? JRC IOWA Lawn and Garden Tractor Accessories 11 02-26-2013 11:50 AM
Wisconsin WI-390/Subaru EY40 carburator repair linrick1 Small Engines and Repair 17 01-19-2013 05:00 PM
