Ingersoll 222 Steering - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 3 Old 03-08-2019, 12:07 PM Thread Starter
jrottman's Avatar
My Ingersoll 222 HyDrive is having problems turning right while in drive. I can still turn left just fine. But when I turn right, the steering wheel just kind of clicks and the wheels don't move.
Interestingly.... if I go in reverse, I can turn the steering and the wheels to the right. Seems like I might have a problem with the steering gear? I haven't done any tear-down yet, will wait until its warmers in Michigan. Is this difficult to get access to check this part and to remove it? Can anyone give me guidance of where to start? Thanks!
Jason
jrottman is offline
post #2 of 3 Old 03-08-2019, 01:16 PM
Re: Ingersoll 222 Steering
Two likely causes:
1. the sector gear needs to be adjusted upward to mesh with the pinion. Easy to do, just remove the nut holding the gear on the shaft, and check for the adjusting shims location. There are normally 2 or 3 and can be on the bottom or top of the gear. Placing them on the bottom moves the gear upward.
2. The gear itself is worn past the point that adjustment will help. That requires a replacement. If that's the case, and you are interested in a used part, drop me a PM. I was rearranging my parts stash and found a couple that I'll never need. Cheaper than new!
antiqueetc is offline
post #3 of 3 Old 03-09-2019, 10:10 PM
Ingersoll Dealer
bhildret's Avatar
If you have the owner's manual, a written procedure is there also for the shimming/adjustment of the gear that antiqueetc has described. Real simple to do.
New gears are also readily available a good used one is generally also fine when you can find them.
Brian
Brian Hildreth
President - Salem Power Equipment, LLC
www.SalemPwr.com
[email protected]
bhildret is offline
Ingersoll 222 Can't start, power issue? jrottman Case_Ingersoll_Colt Forum 6 03-09-2019 10:27 AM
Case 222 steering wheel Hoss2000 Case_Ingersoll_Colt Forum 16 12-05-2018 06:46 PM
GT 3204 Power Steering gcarz102 Cub Cadet Forum 12 06-30-2018 04:12 AM
Tractors, 90's - 2000 Vintage, Steering Problems Part #1 andyjw Backyard Round Table - L & G Tractor Related Topics 10 04-02-2013 04:35 PM
