case 448 slow lift - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 3 Old 01-24-2019, 03:15 PM Thread Starter
case 448 slow lift
hi i got a case 448 and the lift cynlinder is slow need help
ste_clem1974 is offline
post #2 of 3 Old 01-25-2019, 03:45 PM
Re: case 448 slow lift
I would take the lift cylinder out ckeck the O- rings and seals. Before you remove the cylinder check for leaks
G.Paul is offline
post #3 of 3 Old 01-26-2019, 02:09 PM
Is it slow up and down? If not, adjust the linkage for proper movement both ways. If it is, there must be an obstruction. That is assuming travel speed is normal which indicates the pump is working ok.
If it moves quicker with no weight on the arms, the relief valve either needs adjustment or the spring is broken.
antiqueetc is offline
