Case 446 value - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 25 Old 12-17-2018, 11:10 AM Thread Starter
Case 446 value
I’ve been looking around for something a little heavier than a regular garden tractor to play with and found one for sale. This is what they posted. Asking $500. Worth it?
1975 case 446 garden tractor. 18hp Onan BF series motor. Barn find. Has been sitting for quite a while. Has mower deck. No other attachments. Do have another engine and tractor that can throw in with the right offer. Selling for my dad. [hidden information]. Needs to go Read Less
moostang is offline
post #2 of 25 Old 12-17-2018, 11:49 AM
MARK (LI)'s Avatar
Re: Case 446 value
If you are good with tools this could be a steal...even if it needs some work...I see some missing steering wheels, been sitting outside for a long time, tires rotted where the sellers ask over $700....grab it before it gets away and good luck with it
MARK (LI) is offline
post #3 of 25 Old 12-17-2018, 01:55 PM Thread Starter
Thanks. Looks like it’s mostly complete and has wheel weights. The hydraulic lines on the back don’t look they are that old so hopefully it was maintained before it was parked. I haven’t worked on an onan before but I’ve done just about everything on a lawn tractor.
moostang is offline
post #4 of 25 Old 12-17-2018, 02:38 PM
Re: Case 446 value
Originally Posted by moostang View Post
Iíve been looking around for something a little heavier than a regular garden tractor to play with and found one for sale. This is what they posted. Asking $500. Worth it?
Can you post a picture of the tractor
G.Paul is offline
post #5 of 25 Old 12-17-2018, 10:06 PM Thread Starter
I’ll try to post some pictures. I asked him if he could send them to me. I couldn’t figure out how to copy them from Facebook market
moostang is offline
post #6 of 25 Old 12-17-2018, 11:53 PM
Steve Urquell's Avatar
Re: Case 446 value
Iíll try to post some pictures. I asked him if he could send them to me. I couldnít figure out how to copy them from Facebook market
Use "snipping tool" if running Windows. You can search for it after hitting the start button pane where it says "search programs and files" Then save a shortcut to your desktop cuz you'll use it a lot.
Steve Urquell is online now
post #7 of 25 Old 12-17-2018, 11:58 PM
Re: Case 446 value
Here's one near me in MO for $600. It's a steal running with a 3pt and front blade. Wife would kill me if I dragged it home tho.
https://www.facebook.com/marketplace...29204991327142
post #8 of 25 Old 12-18-2018, 06:45 AM Thread Starter
Re: Case 446 value
Here are a few pictures.
ID:	2352345   Click image for larger version
ID:	2352347   Click image for larger version
ID:	2352349   Click image for larger version
moostang is offline
post #9 of 25 Old 12-18-2018, 07:31 AM
Looks like a neat tractor. Did you snip the pics?
post #10 of 25 Old 12-18-2018, 07:49 AM
MARK (LI)'s Avatar
Re: Case 446 value
It looks like it could use a little work, but well worth 500 dollars
post #11 of 25 Old 12-18-2018, 10:03 AM
Re: Case 446 value
Yep, the Hydraulic PTO on that thing is worth $300 in parts, the wheel weights are worth $75 to $100 each. The Case tractors are TANKs.
That tractor has been modified, there is an electric clutch on the front of the engine that is used to drive the mower and or snowblower. I don't recall if there was an optional conversion kit for that or not. You'll need to ask the Guru's over at https://casecoltingersoll.com Bill at Barneveld Implement could answer that kind of question.
If you do snag it, my suggestion based on what I am finding in a 'Barn find' I am working, on, and I know the 1st thing you will want to do is see if the engine runs, but you need to pull the heads and valve covers off that thing and make sure things are not rusted up. Main problem is that the rust WILL rub off the valve stems and cylinder walls, and act like sand paper in the engine. THe Onan B43 engine in that guy does not have an oil filter on it. the process is fairly simple its, basically the process Onan Calls Decarboning the engine.. But with it setting on a dirt floor there could be ALOT of moisture in and on that tractor.. I wonder what the underside of that mower deck looks like??
Also if you want to see more of what that tractor looks like torn down, my Buddy Lionel on the Case forum does an insane job of restoring tractors and documenting the process with pictures, there is a thread: https://casecoltingersoll.com/showth...ct-another-446 where he did a 2 tone 446 similar to this one, in those pictures he'll get it all of the way down to the frame.
1973 Case 646 (w/Custom Power Steering)
1968 Case 155
1958 JI Case 310 Terratrac Crawler Loader
sddunt is offline
post #12 of 25 Old 12-18-2018, 12:51 PM Thread Starter
Re: Case 446 value
Thanks for the information! That's good to know. I'm going to give him a call this afternoon and see what we can do. Unfortunately I had to buy a new fridge last night, so I'm a little short on cash. Maybe he will be willing to trade for partial or I can talk the wife into using a little out of the bank.
moostang is offline
post #13 of 25 Old 12-18-2018, 01:34 PM
Re: Case 446 value
Umm, don' t know where you are in relationship to Brazil, Indiana, but for $350 you could get a bit newer, but also a little more beat up tractor: https://indianapolis.craigslist.org/grd/6774279314.html
BUT, if you want to put a tiller or hydrovac, or run a log splitter, etc, there is NO PTO valve on the $350 tractor, there is a PTO on the $500 tractor. (and the $500 tractor has wheel weights that you need for a blade, or snowblower use to be effective..)
1968 Case 155
sddunt is offline
post #14 of 25 Old 12-18-2018, 05:01 PM
Re: Case 446 value
Basing my opinion on what I just bought $ 350.00 would be a good price
G.Paul is offline
post #15 of 25 Old 12-19-2018, 12:00 PM Thread Starter
Well it sold. Didn’t even get to talk to him left message but no response. Well at least I know what I want now after doing some research on this one. There is a nice 444 with a snow blower but it’s $900. More than I want to spend right now
moostang is offline
