Food for Thought - 4x4 Case 44x - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 9 Old 07-13-2018, 09:46 AM Thread Starter
Dcurtis's Avatar
Has anyone converted their Case 442/444/446 to 4x4? It is always more complicated than it looks, but why can't you tap off the rear hydraulic and drive a pair of front motors at the font wheels? There will be a turning issue and some how all the wheels have to turn at the same speed but image a 4x4 Case 44x , of course you can just upgrade to a bigger 4wd Case, but why, when you can spend more money and time to do your own fabrication?
My goal is build a FEL and expect to trash my front axle/steering gear/spindles etc... (I really hope not), and if I ever have to gut the front end... it would a good time to go 4x4.
Just Food for thought.
1974 Case 446 (18 HP)
- Sleeve hitch, PTO Control Valve, Front Blower x3, Tiller, Deck x3 and Homemade rear blade.
1977 Case 444 (16 Hp) with loader and 3ph - under resurrection.
198x Case 44x (20hp) to be an Articulated BEAST!
Currently designing my versatile Articulating Tractor/loader/hoe. Any thoughts are welcomed.
Plans and creative ideas ALWAYS welcomed - PM me. eg: 3PH gizmo to mow a steep hill - HELP!
Dcurtis is offline
post #2 of 9 Old 07-26-2018, 07:22 PM Thread Starter
Dcurtis's Avatar
Re: Food for Thought - 4x4 Case 44x
So the Answer is articulating. 4x4 AND powersteering. lots of strength for a loader too. Any backhoe plans around (free)?
Dcurtis is offline
post #3 of 9 Old 07-31-2018, 04:47 PM
BowlBuilder's Avatar
The only thing I remember about this is it was built so the complete frame etc could be unbolted and replaced as a unit.
BowlBuilder is offline
post #4 of 9 Old 07-31-2018, 09:43 PM
He also used an automobile u-joint as his swivel point. Giving it full range of motion with just one joint.
post #5 of 9 Old 08-02-2018, 11:17 AM
I like the back fenders turned around to make front fenders.
I wonder how long it is.
I think I sit on the cargo box like a cross between a Gravely and Pasquali.
Hydronerd is offline
post #6 of 9 Old 09-12-2018, 10:05 PM Thread Starter
Dcurtis's Avatar
Me thinks I'd have to redesign fenders to resize for a change in wheel diameter. I have plans for a reverse ram metal press that would make light work of metal bending (will probably make it 4' wide).If I widen the stance, I will have to figure out another way to connect the fenders. I do have a spare set of fenders if you need any. (kinda rough). The price will be right (bring your tools). Tool rental will cost you.
Dcurtis is offline
post #7 of 9 Old 09-13-2018, 09:17 AM
Fenders are cosmetic. Nice to have of course, but kinda a final touch. But I say the project is finished even if I'm sitting on a milk crate. Functionality is my goal.
Metal press plans; that's interesting. Does it need a hydraulic cylinder and power unit?
post #8 of 9 Old 09-13-2018, 09:26 AM Thread Starter
Dcurtis's Avatar
I have a 12ton pneumatic bottle Jack waiting to be installed)
Dcurtis is offline
post #9 of 9 Old 09-02-2019, 08:58 AM Thread Starter
Dcurtis's Avatar
I'm still in the design stages (1 year later). I am considering adding a Backhoe to this beast and would like to design the rear with a frame mount for BX type hoe. Does anyone have a BX 2360 or similar that would provide measurements of the rear hoe mount. Hole sizes and spacing, width (inside and out), height from the ground. Alignment of the holes and distance from the axle. The thickness of the mount also. Later I can just buy a BX hoe for it or build one.
thanks
Dcurtis is offline
