Murray Widebody 14 hp B&S carb - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 10 Old 05-08-2011, 05:15 PM Thread Starter
texas lawn ranger's Avatar
Hey guys,
I'm stumped with the carb on my B&S 14 hp engine. It was running fine, then it stopped. Checked fuel line, no clogged filter. Took of solenoid, bowl, etc. Everything appears okay. Cranks it over and over and it won't start. Poured some gas after removing the air cleaner and it catches, runs for a few seconds then dies. Also replaced spark plug. Still can't get it to run. I'm going to try seafoam in the gas tank. Don't want to take carb apart.
Hmmm. What do you guys think?
texas lawn ranger is offline
post #2 of 10 Old 05-08-2011, 07:53 PM
Slow Crawler's Avatar
Re: Murray Widebody 14 hp B&S carb
Sound like a sticking float to me. the sea foam will only work if you can keep it running. Good luck
66 Suburban 10
73 ST/10 For parts
73 ST/12 Frankinburban
77 Sears 16/6 twin
88 Craftsman III Sold
84,86 Murray 18/42 gt mowing tractors Sold the 86
85 Murray 18/42 The Slow Crawler
96 Craftsman 917.251560, 22.5 Hp 50" cut
03 Huskee, MTD 18.5/ 42
Slow Crawler is offline
post #3 of 10 Old 05-08-2011, 07:59 PM
SonnyT's Avatar
If it isn't running I don't think the Seafoam will help. You might just have to take the Carb apart and look at the needle/float first.
RIP Sonny T.
1954-2015
SonnyT is offline
post #4 of 10 Old 05-08-2011, 09:22 PM
Old Iron......Forever
hankll's Avatar
Send a message via Yahoo to hankll
The fuel bowl after fire solenoid may be defective. Check it to see if the plunger is activating with the key switch. It should retract with the key on and go back out with it off. If not working, there is your problem. The plunger stops fuel flow to the main jet. If you don't plan to replace it, you can snip the plunger off and it will run. Just be aware that the mower should be idled down for a about 30 seconds before shut off or it will do the after fire through the muffler.
hankll is offline
post #5 of 10 Old 05-15-2011, 12:32 PM Thread Starter
Thanks to everyone for the advice. I will look at the solenoid first to see if it's working. Might have to take the carb apart to check for a sticking float and needle. Just got a cool front that came it, making pleasant to work outside. Wish I could be mowing instead of wrenching.
post #6 of 10 Old 10-14-2011, 09:42 PM Thread Starter
Okay guys, it's middle of October and we finally got rain in South Texas. Murray still won't start. New spark plug, cleaned out the gas tank, new fuel filter, new battery. Cranks and cranks and won't start. Grass is getting taller. Spark is visible at the end of the plug.
Carb problem or coil needs replacement?
post #7 of 10 Old 10-14-2011, 10:38 PM
Senior MTF Poster
Did you check out the fuel solenoid as suggested above? Got fuel, got spark, remove the cooling shroud, remove the flywheel screen, remove the flywheel nut or bolt, look down the keyway to see if crankshaft and flywheel keyways line up, use pen light. if not sheared or partially sheared flywheel key.
Walt Conner
Walt 2002 is offline
post #8 of 10 Old 10-15-2011, 11:48 AM Thread Starter
Thanks, Walt.
I will do all that and get back with you. As always, mytractorforum is great!
post #9 of 10 Old 10-15-2011, 02:34 PM
BushBoneYard's Avatar
If you need help with the fuel solenoid, I found this video useful....
http://youtu.be/HKI7qI7iIBE
New members with 0 posts, please do not ask me ?'s via p.m. Post on the open board so that all can benefit.
1977 Murray Built Sears ST 10 Yard and Garden Tractor
1984 Murray 39004 Garden Tractor
1999 Murray 46500 Lawn Tractor
2007 Husqvarna Built Craftsman YS4500
MurrayOwnersWorld.com
M.O.W. Facebook
BushBoneYard is offline
post #10 of 10 Old 10-15-2011, 11:24 PM Thread Starter
Thanks BushBoneYard. I'll try and see if it's a wiring problem tomorrow. In the mean time, I had to borrow a neighbor's riding mower to cut the grass before it becomes a jungle.
