1614 spark issues - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
Power King & Economy Tractors Power King, Power Queen, Jim Dandy Tractor Brands
post #1 of 5 Old 08-17-2019, 08:57 PM Thread Starter
Cut&fit's Avatar
1614 spark issues
Hello all,
Ive been having a heck of a time trying to diagnose and repair my 14 hp Kohler K321, with no spark. I have the breakerless ignition and thought my trigger module had gone south after testing the diodes so I replaced it and still no spark. I can't find anything in my Kohler manual about testing the ignition windings in the stator. I did put my multimeter on the stator terminal on the module and cranked the engine and got a reading of around 16-18 volts, not sure if I'm doing that correctly. I'll admit I'm electronically challenged and the digital multimeter tends to confound me as much as it helps me. I'm seriously considering just converting the ignition over to breaker points and being done with it. Does anyone have any insight into testing the stator, and are the ignition windings different from the alternator windings? I don't want to go to the trouble of converting to points and later find out my alternator won't charge my battery and have to tear it all back apart.
1975 Power King, 1995 John Deere 425.
Cut&fit is offline
post #2 of 5 Old 08-18-2019, 01:53 AM
Collector of many tractors
Kbeitz's Avatar
Re: 1614 spark issues
Coil tester....
Name:	Coil tester.jpg
Kbeitz is online now
post #3 of 5 Old 08-18-2019, 08:48 AM
GB in MN's Avatar
Hi Cut&fit, there are 2 stator coils one is for the charging system those wire come out on the left side of the engine above/near the starter the ignition charge wires are on the right side at the trigger if you have voltage on those wires the ignition stator coil is ok make sure the coil is well grounded this system is real picky about have a good ground if you still can't get spark them the best option is to convert it to battery / points ignition I've attached a couple of manual in case you don't have them
Kohler Breakerless Ignition.pdf
Kohler Battery Ignition Conversion Kit.pdf
GB in MN
72 Sears G16 Suburban "S3"
67 Sears Suburban 12 "S1"
48 Earthmaster Model C
60 Sears Suburban DB
66 Sears Suburban 10 "S2"
48 Ford 8N
58 Ford 641
63 Oliver 770
04 Sears GT5000
75 Sears ST 16 S4
75 Sears SB 18 S5
74 Sears SS16 S6
84 Power King 1618
76 Power king 1614
73 Power King 1614
1949 Economy Standard
1943 John Deere LA
GB in MN is offline
post #4 of 5 Old 08-18-2019, 09:55 PM Thread Starter
Cut&fit's Avatar
Interesting coil tester.
GB, thanks for the info. Everything seems to point to the coil and since those seem to be pretty much non-existant anymore, I'm going the points and condenser route. I've been advised many times over on the facebook page that it's the best way to go. I've already bought and paid too much for the trigger module so I'm cutting my losses. Maybe I'll be able to sell the module and recoup some of my investment.
Cut&fit is offline
post #5 of 5 Old 08-18-2019, 10:08 PM
GB in MN's Avatar
Hi yes the points are a tried and true system I know that's what I would do I have one tractor with the Kohler breakerless system if it goes it will get points, on my other 2 tractors / Kohlers I've converted them to Kirk Engines point saver system its a hybrid electronic system works good.
GB in MN
48 Ford 8N
58 Ford 641
63 Oliver 770
04 Sears GT5000
75 Sears ST 16 S4
75 Sears SB 18 S5
74 Sears SS16 S6
84 Power King 1618
76 Power king 1614
73 Power King 1614
1943 John Deere LA
GB in MN is offline
