When is it time to replace a mower deck shell? - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
Power King & Economy Tractors Power King, Power Queen, Jim Dandy Tractor Brands
post #1 of 26 Old 05-05-2019, 12:08 AM Thread Starter
I have the original 48" mower deck that came with my tractor that has seen nearly 40 years of grass mowing. I intend to keep this tractor running for another 40 years, so I'm considering what kind of attention I should give this deck as I get ready for another season.
As I was prepping the deck tonight, I noticed:
  • the rust underneath is getting quite bad in a couple spots
  • I have 2 holes rusted through - 1 between the middle and left spindle as you are looking at the photo, the other is on the left side of the deck
  • the baffle (not sure on the technical name - the curved piece that follows the arc of the blades) is about 70% rusted away
  • I mistakenly hit a stump that was hidden in some long grass. It bent the front edge of the deck in, to the extent that the blade hit that front edge. I bent it back out to get it functional, but it isn't pretty
The top side of the deck still looks decent, but I know that mower deck "shells" are still available from Mission Manuf. I will have to contact them for a quote, but I'm trying to weigh what I would need to do to get this deck back to 100% versus buying a new one while I still can.
I have considering grabbing a used one somewhere, but most of the time they are not much better than what I have.
I'd be curious to hear everyone's thoughts! Thanks!
ID:	2375215   Click image for larger version
1979 Power King 1618
Dual trans., turf tires, hydraulics, Cat 0 3 pt., 48" mower, snowblower, rototiller, dethatcher rake...more attachments to come
zuren is offline
post #2 of 26 Old 05-05-2019, 01:55 AM
Country1966?'s Avatar
You don't say what it is off of and that information would play into my answer.
Assuming you do have a piece of equipment that will last another 40 years I say bite the bullet and buy a new deck.
Country1966? is online now
post #3 of 26 Old 05-05-2019, 02:13 AM
Re: When is it time to replace a mower deck shell?
I would just start welding patches over the holes and using my ring-roller to make new curved pieces that go near the rear edges of the 3 blades (it's a 1" ring roller, but I've done 4" wide 1/8" thick sheetmetal with it).
dave_r is online now
post #4 of 26 Old 05-05-2019, 02:20 AM
I'm with Country, once a deck starts to go its gone. Had a Craftsman 46" deck that started cracking. I mad maxed it together for a while but other cracks were starting.
T.Cruit is offline
post #5 of 26 Old 05-05-2019, 11:10 PM
Hammerhead007's Avatar
I would also agree with replacing the deck. Fix what you can for now to get you by, but start pricing out a new or good used one for next year. Once you start welding on this you will eventually pass the cost of a replacement deck. This deck has seen 40 years of use and abuse and metal fatigue has set in. Rust is making the hole deck thinner as the years go by and she has had a great run. If it were me, i'd patch for now but start looking for a replacement.
Hammerhead007 is offline
post #6 of 26 Old 05-05-2019, 11:55 PM
not quins. but sextuplets
Whirly's Avatar
I don't think he'll find a replacement for a 40 year mower.. JD gives u 20 years of parts.. after that ur on ur own.. patching it would b the way to go..
the round fenderd JD's
total tractors is 30..
Whirly is offline
post #7 of 26 Old 05-06-2019, 02:22 PM Thread Starter
Actually, not true. Mission Manuf. has them available:
https://powerkingtractor.com/Info/LE...GE48-60482.htm
Just got the quote back - $595 for the bare shell. That did not seem to include freight.
zuren is offline
post #8 of 26 Old 05-06-2019, 02:23 PM Thread Starter
See my signature...
zuren is offline
post #9 of 26 Old 05-06-2019, 09:37 PM
Whirly's Avatar
this is the first time u mentioned it was a Power King.. they r a collectors item.. retire that tractor..
Whirly is offline
post #10 of 26 Old 05-06-2019, 11:04 PM Thread Starter
I don't want to sound flippant, but I am posting in the Power King forum...and posted pictures of a Power King deck in front of a Power King tractor...with a Power King listed in my signature.
And I'm not sure if you are joking, but I was unaware that PKs are to be retired. There are plenty of folks here still working these machines.
zuren is offline
post #11 of 26 Old 05-13-2019, 12:40 PM
Senior MTF Pollster
Austen's Avatar
That's great you're keeping the tractor alive and using it as intended. They are great mowing machines and offer a nice cut. I really enjoy mowing with mine too.
That said, if you can justify the cost of a new shell, that would be the way to go. I'd coat the underside with POR 15 before using it to help preserve it. Otherwise if you want to keep your existing one alive, you could get some quotes to have the metal repaired if you're not a fabricator however the cost would likely be near same or exceed what the new shell would be. If you can't find any good used replacements, I'd suggest buying a new shell (though expensive) but will last another 40+ years like you said, especially with a good coating on it from the start. My $02c.
Bolens HDT1000 #11- Coming eventually!
1977 Economy Tractor
Hydraulic lift conversion
24" model front king pins
48" Belly mower
32" tiller
3pt hitch
”What joy for those whose strength comes from the Lord." - Psalm 84:5
Austen is online now
post #12 of 26 Old 05-13-2019, 02:31 PM
Not trying to start a fight but it wasn't until post 7 that I realized it was a Power King. Still... Patching it will be time intensive and only temporary. Been there done that with a Craftsman. The only reason yours lasted so long is because the quality was better to start with. In my honest opinion.
T.Cruit is offline
post #13 of 26 Old 05-13-2019, 02:52 PM
MARK (LI)'s Avatar
I think that you are missing a few rollers also...I think Whirly was suggesting retirement because it is collectible and as such you would want to preserve it...on the other hand it is a collectible because it was so good when it was made, that it should be able to work forever.....I would patch as I can for now....those holes are not really a big deal....the arc baffles would take a little bit of work, but could be done even if only temporarily until you decide to buy a new deck or find a used one....good luck with it...if I owned it...I would want to keep it working and as well maintained as I could
MARK (LI) is online now
post #14 of 26 Old 05-13-2019, 07:54 PM
I have my Grandfather's Economy, he lived next door on the farm, bought it new with a bunch of attachments. My deck is under roof on asphalt (just noticed full of leaves). Dad brush painted it many years ago (latex...so maybe I can get it off).
Your deck doesn't look that bad. If it were mine I would clean rust hole areas to bare metal on inside...patch same gauge steel pieces larger like 3"x3"...whatever works. Braze them in (inside deck). Outside fill (if you get it clean enough I'd be tempted to lead solder hole area). Sand, prime, paint both sides. Replace roller.
You have nothing to lose. Fixed up it will last another 40+ years.
Grandad (rip), Dad (rip), and I (I'm 67) have put this one to hard use and it works great.
They were/are great and handy little tractors and I'm still amazed what it will do.
Sent from my SM-S320VL using Tapatalk
Sevenhills1952 is offline
post #15 of 26 Old 05-14-2019, 12:16 AM
Whirly's Avatar
I'm wondering if u can get a brand new tractor from them..
Whirly is offline
Help installing a mower deck on a 5518. Mannyj Honda 7 07-09-2018 09:08 PM
Anyone have the mower deck arms for GT3000? bobotech Craftsman/Sears Forum 1 06-28-2018 09:54 PM
208 Mower deck makes too much NOISE wndoguy John Deere Forum 18 03-22-2013 05:50 PM
what would cause engine vibration when mower deck is engaged?? craftsman 16 hp briggs ericwest Craftsman/Sears Forum 9 12-07-2012 08:38 PM
Mower Deck ???'s 69 140 H3 DEUCE1068 John Deere Forum 11 11-30-2012 10:31 AM
