New Economy to me - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
Power King & Economy Tractors Power King, Power Queen, Jim Dandy Tractor Brands
post #1 of 18 Old 04-10-2019, 08:28 PM Thread Starter
Red face New Economy to me
I just bought this at an auction sight unseen Click image for larger version
Name:	economy new to me.png
I think it is Panzer Blue.
Looked to have recent fronts, and the metal seemed straight.
I believe it has hydraulics.
Did they ever come in this color?
Came with what looks to be a brinley disc and a deck.
llawrence9 is offline
post #2 of 18 Old 04-10-2019, 08:43 PM
Re: New Economy to me
Mine, grandfather bought new is orange...very close to Chevy engine orange and that's all the ones I've ever seen were orange. Yours looks like good paint and good condition, I like the blue.
I used mine a lot yesterday. Amazing little tractors.
Sent from my Bell Rotary
Sevenhills1952 is online now
post #3 of 18 Old 04-10-2019, 11:39 PM
I like the blue.
I'm thinking of making one my 2414's john Deere colors just for whenever heck of it.
Chevyman29 is offline
post #4 of 18 Old 04-11-2019, 09:58 PM
GB in MN's Avatar
Hi all after the 50's came from the factory painted Case Flambeau Red (looks orange) the factory had a few blue one and I think green in the 40's and early 50's but used the Case Flambeau Red for all after the few different colors.
If you like the color you have a nice tractor
GB in MN
72 Sears G16 Suburban "S3"
67 Sears Suburban 12 "S1"
48 Earthmaster Model C
60 Sears Suburban DB
66 Sears Suburban 10 "S2"
48 Ford 8N
58 Ford 641
63 Oliver 770
04 Sears GT5000
75 Sears ST 16 S4
75 Sears SB 18 S5
74 Sears SS16 S6
84 Power King 1618
76 Power king 1614
73 Power King 1614
1949 Economy Standard
1943 John Deere LA
GB in MN is offline
post #5 of 18 Old 04-13-2019, 09:23 AM Thread Starter
Unhappy Re: New Economy to me
got it home. the smell of varnish in thetank yuck
Name:	auction ap 13 2019-03-13 004.JPG
ID:	2371621   Click image for larger version
Name:	auction ap 13 2019-03-13 005.JPG
post #6 of 18 Old 04-13-2019, 12:31 PM Thread Starter
I am having a hard time figuring out which deck drive belt to purchase. The download is a bit blurred. Could someone please advise on this 16'' wheels 14 hp Kphler with a 48'' deck.
post #7 of 18 Old 04-13-2019, 12:41 PM
GB in MN's Avatar
Hi post a picture of the deck and hitch/mule drive there are two types of hitches so the belts are different
Ok I see your tractor dosen't have the quick hitch blocks so the mule drive belt should be a A85 1/2" X 87"
GB in MN
48 Ford 8N
58 Ford 641
63 Oliver 770
04 Sears GT5000
75 Sears ST 16 S4
75 Sears SB 18 S5
74 Sears SS16 S6
84 Power King 1618
76 Power king 1614
73 Power King 1614
1943 John Deere LA
GB in MN is offline
post #8 of 18 Old 04-13-2019, 03:41 PM Thread Starter
Thank you. Is there a particular brand that seems to give you better service?
I'm playing with the carb now,
I hate ethanol.
post #9 of 18 Old 04-13-2019, 06:04 PM
GB in MN's Avatar
Hi, no brand but the Kevlar belts do stand up better, what kind of carb problems are you having? Just to be a spoiler I doubt ethanol is the problem, here in Minnesota we've had 10% ethanol since the early 80's with no problems once the gas lines were replaced it does and will clean the gunk out of the fuel system and require filter changes at first.
GB in MN
48 Ford 8N
58 Ford 641
63 Oliver 770
04 Sears GT5000
75 Sears ST 16 S4
75 Sears SB 18 S5
74 Sears SS16 S6
84 Power King 1618
76 Power king 1614
73 Power King 1614
1943 John Deere LA
GB in MN is offline
post #10 of 18 Old 04-13-2019, 07:23 PM Thread Starter
Carb bowl had dirt in the bottom. Fuel lines will need replacing, and that will be another day. New petcock needed as well. The old gravel in the gas tank I guess.
What has us confused is the coil. No spark at the plug.
Is this a cdi ignition?
The lead to the bottom of the coil is not receiving power. Does one of these wires go to the trigger?
The lead at the ignition switch that goes to the coil is not producing power.
Switch will crank engine. No fire
Checked continuity on the wire. Good to the switch.
Is there a schematic for this k321 showing the ignition switch?
ID:	2371743   Click image for larger version
post #11 of 18 Old 04-13-2019, 07:30 PM
GB in MN's Avatar
Hi yes that is the Kohler breakerless magneto ignition system and its good that you have no power as that will burn it in less than a second and replacements are out of this world expensive, most convert to battery / points ignition if they have trouble, if it starts and runs do nothing.
GB in MN
48 Ford 8N
58 Ford 641
63 Oliver 770
04 Sears GT5000
75 Sears ST 16 S4
75 Sears SB 18 S5
74 Sears SS16 S6
84 Power King 1618
76 Power king 1614
73 Power King 1614
1943 John Deere LA
GB in MN is offline
post #12 of 18 Old 04-13-2019, 08:25 PM Thread Starter
It does not start and run.
I get no power readings at the coil.
Is power generated and does that power trigger the coil?
The ignition switch when off is a ground?
post #13 of 18 Old 04-13-2019, 08:49 PM Thread Starter
Is there a non oem breakerless ignition I could install? Or a video on the change over to points?
post #14 of 18 Old 04-13-2019, 09:56 PM
GB in MN's Avatar
Originally Posted by llawrence9 View Post
It does not start anun.
Yes when the switch is off the mag is grounded
Under the flywheel the stator has a excite coil to power the system there is a trigger module under the cooling cover
there should be no power readings at the coil.
There are no plug and play aftermarket systems at one time Kohler had a reofit points kit I'll attach some PDF manuals
Kohler Breakerless Ignition.pdf
Kohler Battery Ignition Conversion Kit.pdf
GB in MN
48 Ford 8N
58 Ford 641
63 Oliver 770
04 Sears GT5000
75 Sears ST 16 S4
75 Sears SB 18 S5
74 Sears SS16 S6
84 Power King 1618
76 Power king 1614
73 Power King 1614
1943 John Deere LA
GB in MN is offline
post #15 of 18 Old 04-14-2019, 10:38 AM Thread Starter
I found out that Kohler at one time made a kit to allow the installation of points for these engines,
237750-s but that involves the teardown of the engine to get blocking plug you drive in out. You can rob the guts of a points system from most k engines, I was lead to believe and get the parts that way.
Aftermarket cdi systems do exist.
The compression seems low and there are signs of oil leakage everywhereon a unit that may well have 2000 hours on it.
It has a good deck and like new tires and recent clutch. . I will sell it for $400 and break even if I can't find a modern donor engine. 2100 series cub cadets are a likely donor, having been used by others before. Someone is interested in the k engine alone.
In my head I have already moved on. Thank you all very much for your time and wisdom.
New to me Economy Power King. bonusbuilt1950 Power King & Economy Tractors 7 08-11-2018 07:10 PM
First Economy Jr. Bradley Power King & Economy Tractors 5 02-14-2013 10:33 PM
318 & 49 Blower fuel economy question itsjojo John Deere Forum 25 12-30-2012 01:31 PM
