1978 Power King 1614 - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
Power King & Economy Tractors Power King, Power Queen, Jim Dandy Tractor Brands
post #1 of 10 Old 10-27-2018, 10:13 AM Thread Starter
So I picked up this long neglected little tractor in the hopes of giving it a fresh start and me a winter project. I've never done anything like this before and as best as I can tell everything needs to be gone through. Pretty sure there is not one more place this tractor could possibly leak from.
As i have been going through the tractor i have been making lists of known parts and pieces I'll have to get. The engine (K321), electrical, and other miscellaneous items have been somewhat easy to find a source for. However, there are several things I haven't really been able to locate. In particular:
Gaskets, bearings and seals for the drive system (clutch - finals) and the electric pto clutch. My pto looks fried and i would like to use the mower that came with it.
I have the manuals and parts #'s, but haven't had much luck locating sources on the internet.
Would anyone be willing to share a link or contact information for someone who carries these parts or a part # cross reference for sourcing them locally.
Thank you. Going to go pull the engine today. Wish me luck.
cjtaeda is offline
post #2 of 10 Old 10-27-2018, 11:39 AM
No Quarter's Avatar
Re: 1978 Power King 1614
You might want to check with the Economy / Power King tractor collectors on Facebook if someone here can't help you.
1946 Gibson Model A w/WI 5.9hp
1984 John Deere 318 w/Onan 18hp
1989 John Deere 420 w/Onan 20hp (2)
1990 Craftsman GT6000 w/Briggs 18hp (2)
No Quarter is offline
post #3 of 10 Old 10-27-2018, 09:11 PM
GB in MN's Avatar
Hi cjtaeda welcome to the group and to Power Kings how about posting some pictures, there are a few places to find and get parts there a lot of parts on ebay, this company owns the rights to Power king tractors and mfg parts for them
https://powerkingtractor.com/
Another place is Power King Parts
GB in MN
72 Sears G16 Suburban "S3"
67 Sears Suburban 12 "S1"
48 Earthmaster Model C
60 Sears Suburban DB
66 Sears Suburban 10 "S2"
48 Ford 8N
58 Ford 641
63 Oliver 770
04 Sears GT5000
75 Sears ST 16 S4
75 Sears SB 18 S5
74 Sears SS16 S6
84 Power King 1618
76 Power king 1614
73 Power King 1614
1949 Economy Standard
1943 John Deere LA
GB in MN is offline
post #4 of 10 Old 10-27-2018, 09:43 PM Thread Starter
Here are a few pics from the initial breakdown.
Attachment 2342959
Attachment 2342961
Attachment 2342963
cjtaeda is offline
post #5 of 10 Old 10-27-2018, 11:57 PM
GB in MN's Avatar
Hi looks like your getting it cleaned up you could look on the top of the left frame rail aft of the clutch pedal some had the SN stamped into the frame there
GB in MN
48 Ford 8N
58 Ford 641
63 Oliver 770
04 Sears GT5000
75 Sears ST 16 S4
75 Sears SB 18 S5
74 Sears SS16 S6
84 Power King 1618
76 Power king 1614
73 Power King 1614
1943 John Deere LA
GB in MN is offline
post #6 of 10 Old 11-01-2018, 06:58 AM Thread Starter
It does have the # stamped in it. Just kept forgetting to post a pic i took. Here it is.
cjtaeda is offline
post #7 of 10 Old 11-01-2018, 08:30 AM
GB in MN's Avatar
Hi cjtaeda, thanks for posting that the SN make your tractor a 1979 model hows the refurbish comig?
GB in MN
48 Ford 8N
58 Ford 641
63 Oliver 770
04 Sears GT5000
75 Sears ST 16 S4
75 Sears SB 18 S5
74 Sears SS16 S6
84 Power King 1618
76 Power king 1614
73 Power King 1614
1943 John Deere LA
GB in MN is offline
post #8 of 10 Old 11-05-2018, 05:04 PM
Senior MTF Pollster
Austen's Avatar
Cool project tractor!
I'll second the links that Gary posted above for finding new parts.
Bolens HDT1000 #11- Coming eventually!
1977 Economy Tractor
Hydraulic lift conversion
24" model front king pins
48" Belly mower
32" tiller
3pt hitch
"So I say to you, ask, and it will be given to you; seek, and you will find; knock, and it will be opened to you." - Luke 11:9
Austen is online now
post #9 of 10 Old 01-09-2019, 10:30 PM Thread Starter
Thought I would give a quick update. Decided to only work on one or two major items at a time since I have zero experience doing this and having to figure it out as I go. Almost done with the engine rebuild. Plan to get it finished, try and test run it and then put it in the corner of the shop until much later. I have new bearings for the tranny and will tackle that next. Any tricks to reassembling upper transmission shaft with the 13 individual roller bearings? Seems like it will be hard to mate the two piece shaft back together while keeping those little boogers in the right place.
I originally stated this was a 78 model tractor, but then I included a picture of my frame serial # stamp and was corrected it was a 79. Later thought this didn't sound right so went back and looked. Noticed all the stickers on the sheet metal had a matching but different serial number than the frame stamp. All the digits are the same in the sheet metal and frame. Only difference is two of the digits in the frame # are reversed. Is there any way to tell which is correct? I am pretty sure its an all original tractor. Doesn't really matter, just curious.
More to come...
ID:	2356037   Click image for larger version
cjtaeda is offline
post #10 of 10 Old 09-08-2019, 09:21 PM
joecdeere's Avatar
just hold them in place with some wheel bearing grease or white lube
1948 Allis UC Hi-Crop Cane
1941 Allis WC
1948 Allis G
1948 Allis G
1949 Allis G
1954 Allis G
1959 Ferguson TO-35
1972 MF 135
1979 Power King 2418
1989 Ford 345C TLB
joecdeere is offline
