Ford 3000, Injection Pump - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 4 Old 06-15-2019, 05:02 PM Thread Starter
GearHeadTom's Avatar
Been helping a buddy of mine with his Ford 3000 diesel, been having issues with Simms injection pump, mainly leaks.
First it started leaking out of what I've read to be a vent/overdflow, on the back end of the pump, leak seemed to come and go.
Had it running again today, and fuel started pouring out of the "hooded" vent, circled in red.
I'm assuming the pump needs rebuilt/replaced? I'm quite confident I could rebuild it, unless it needs some very specialized tools. New pump is not in the buget.
Sent from my SM-G903W using Tapatalk
Tractors:
1970 Bolens 1053 - with snowblower and deck
Craftsman "Redneck-Racer" - old beater ride-on with no so stock sized drive pulleys...
GearHeadTom is offline
post #2 of 4 Old 06-15-2019, 06:35 PM
Re: Ford 3000, Injection Pump
Is that piece circled on the injection pump or the lift pump? Something some have done on a 12V Cummins injection pump when they might start a leak is to mix some oil in the fuel to give the injection pump some lube. Helps lubricate seals that start leaking, doesn't cost much to try before trying to repair it.
9297oldram is offline
post #3 of 4 Old 06-15-2019, 09:32 PM Thread Starter
It's on the injection pump. I think it's to far gone to be saved, steady gushing of fuel out of that vent.
Tractors:
post #4 of 4 Old 06-23-2019, 07:28 PM
Nouveau Redneck's Avatar
The Simms pump has an oil reservoir that is used to lubricate the pump. Some folks don't realize that and never change the oil and it gets contaminated with fuel and the pump does not receive the proper lubrication, and then things begin to go south. The oil in the pump should be changed every time that you change the oil in the engine, and using the same oil that you put in the crankcase.
A full rebuild of the pump requires specialized tools to test the pressures at various points and to set the timing, as well as specialized knowledge. If you are merely replacing some of the seals that can be accessed without complete disassembly of the pump, then you could probably do it yourself, but anything more and I would recommend taking the pump to a diesel pump specialist. Make sure that you follow the instructions in the service manual when you remove the pump so that things will be timed properly when you go to re-install it. And make sure that you don't turn the engine at all while the pump is not installed.
Nouveau Redneck
Sean in PA
2008 John Deere X500
2015 John Deere X530
Nouveau Redneck is offline
