Pertronix 1244A - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 6 Old 05-25-2019, 01:59 AM Thread Starter
Pertronix 1244A
Doing and install this weekend in a 651 1958 Model, any surprises or is it straight forward.
GreyScar is offline
post #2 of 6 Old 05-25-2019, 08:28 PM
Re: Pertronix 1244A
I've done two recently - one on a 4000 4 cly (62 if I remember right) and one on a newly acquired 8n. Straight forward.
Antarctica is offline
post #3 of 6 Old 05-25-2019, 09:19 PM Thread Starter
Re: Pertronix 1244A
Thanks, got it Done, Seems to Idle better. I decided to go this Route because I have Had Terrible Luck with Condenser's. Went ahead and eliminated the Ballast Resistor and upgraded to 3 OHM internally Ballast Coil why I was @ it.
GreyScar is offline
post #4 of 6 Old 05-26-2019, 10:19 AM
Re: Pertronix 1244A
Great. My 4000 ran like a top once I changed it. My (new to me) 8n is still a work in progress.
post #5 of 6 Old 06-10-2019, 11:04 AM
MrChris's Avatar
Re: Pertronix 1244A
I've completed the modification on an old Willys Jeep CJ2A and on my Ford 5000. The only issue I had was that driving the sensor over the distributor post in both cases took a bit more of a push than you would expect. In both cases I used a large socket to apply an even pressure and hit it with a dead blow hammer to drive the piece home.
The rest of the install is simple.
You'll love the result.
Big Ol' Fords.
MrChris is offline
post #6 of 6 Old 06-10-2019, 12:31 PM
Re: Pertronix 1244A
I should also note that when I installed one on my 8n, I had to grind/file the mounting plate just a smidge to get it to clear one of the distributor plate screws.
