Powering a 12 ton boat; need advice on big DC motors - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 54 Old 05-21-2019, 02:09 PM Thread Starter
Mark in Portugal's Avatar
Hi guys;
There are specialty forums for this, but all I get is people who want to sell me new material at 10X my budget.
Really nice looking, but it's not going to happen.
The project; In Amsterdam [Holland] I have a 12 ton 100 year old steel barge I use occasionally for work. Although I only need it rarely, when I need it I really need it.
max speed in the canals is 8mph, distance I need to travel is 3 miles on a charge. 6 would be nice, but the battery cost is another story.
Amsterdam has announced that all vessels must be emission free by 2026. Even now, I'm paying $500 per year penalty for having an internal combustion engine for propulsion.
So, getting to work;
Used forklift motor, 240A 48V, $200 second hand, available now.
pulse width modulated control, new $350, maybe a used one with the motor.
If the motor is 80% efficient [???] it's rated at 12HP. ok for going, a bit light for stopping.
I need some tech info on brush type motors. Amps/ volts / torque / RPM.
How do I achieve short duration overload capability for stopping + turning?
What happens if I gear the motor to turn the prop at 20HP at rated motor speed, then normally reduce that with a pulse width control to keep the rated amps at lower than rated speed?
Next subject;
water cooling.
this will be required even to let the motor run at rated power continuously.
I see 2 ways to do it;
1; add an outer jacket and use glycol solution to cool the motor casing, an intercooler, and 2 waterpumps. The boat already has an intercooler, and the diesel will stay in it for longer transits outside the eco restriction zone.
2; change the motor case for a stainless steel one, with waterjacket.
they're usually just a pipe. I have a lathe. The question that occurs to me is whether the motor needs the magnetic properties of the normal steel tube it's mounted in. 320 stainless isn't magnetic.
I have the time and skill [barely] to do the work.
Because the biggest heat problem is usually the armature windings, I have the idea to add cooling to the shaft; weld a stainless extension and run it through a water chamber.
Does anyone here have any knowledge of this sort of thing?
Mark in Portugal is offline
post #2 of 54 Old 05-21-2019, 11:51 PM
20,000 Posts & Climbing
Re: Powering a 12 ton boat; need advice on big DC motors
Cooling
Can you use a large squirrel cage fan (oversized furnace fan) and duct in cooling air?
The 40 hp table motors at the steel mill where I worked live in an environment that can be as much as 50C and draw air from the oil cellar at 30C for cooling. The motors can be operated on as much as a 20% duty cycle
Rule of thumb - 1 hp electric motor = 1.25 hp gas engine
I'm not sure if a diesel equates the same way.
TUDOR is online now
post #3 of 54 Old 05-22-2019, 06:44 AM Thread Starter
Cooling is a detail at the moment; speed control, reversibility, and how to match the prop to the motor are what I really need to figure out.
sure, I could add a fan, ducts, etc. But I think it will need water cooling to be successful.
I need about 8 hp continuously; well, for 45-60 minutes, which is the same I suppose.
That's a tough job for a DC motor; most are made for short duty cycles.
This forklift motor is probably prehistoric; the plate picture from the ad is hard to read, and in Italian just for added amusement.
Name:	Forklift Motor DC 36 48V.jpg
"servizio", [service] appears to read ".53 [or .58] 25%"
I take that to mean duty cycle. 53 could be temperature C?
If we take the amps x volts from the plate, and compare the result to the KW on the plate, the discrepancy would seem to indicate 69% efficiency at 36V, 72% at 48V
So 3.5kw of heat at 48V; that's a lota heat!
Monitoring the heat of the field coils is easy enough, but it's the armature that always melts first.
this motor is not the right motor; but it's 150 euros, $200. The "right" one is $2,000, + $1,500 for the required control.
and another grand for the batteries.
If I buy this motor, I'll probably control it with straight relays, or even a manual lever switch [I'd have to fabricate that]. So it would have 2 speeds, 24V and 48V; and full reverse.
available controls are not able to handle 240A continuously, 150 seems the max [even though they're called 400A controls].
This motor comes with 'the original oil pump', which I take to mean hydraulic pump. so reversing would have been done hydraulically. This is a series wound motor, not designed reversible.
I would have to extract the armature connections; I've done that before with a starter motor.
The starter motor didn't like reversing. it seemed more sparky, and slower. but it did its job.
This way I'd possibly achieve a usable result at a usable cost.
According the plate, the current is equal at different voltages. the power and rpm decreases.
post #4 of 54 Old 05-22-2019, 08:04 AM
OLD TIRED CDN. MECHANIC
Larry LGT 165's Avatar
I can offer no help with the electrical calculations, execpt to sugest a small electric bow thruster auxillery motor up front for steering. They are common here on fishing boats, especially bass boats for tight turning without using the main engine.
Here when a dealer matches a motor to a boat, they take along several props of different pitches and test to find one that allows the engine to reach full rpm on the chosen vessel without labouring.
If you can water cool, running copper pipe along and back just above the keel is common and replaces the need for any type of radiator/fan. A small coolant circulating pump would possibly consume less electrical power than a larger air cooling fan.
You have our interest Mark, as the day will come such regulations are enforced here as well.
Larry ( in Southern Ontario )
Larry LGT 165 is offline
post #5 of 54 Old 05-22-2019, 10:45 AM
I wonder if instead of one big 12 HP motor,you could use several 12V treadmill motors,I see some rated up to 4.5 HP at the Surplus Center's site ,prices ranging from under $100 to about $200--they are designed for use with variable speed control .
Tractor-Holic is offline
post #6 of 54 Old 05-22-2019, 10:59 AM
Now there's a good thought. You could mount them on a couple old outboard motors with the gas engines removed.
Separate batteries, separate turning for steering if required, props already in place, forward neutral and reverse, and you could leave the original drive system completely separate for when you are out on open water.
post #7 of 54 Old 05-22-2019, 11:17 AM
mda2000's Avatar
If you went with the outboard lower units, that would allow you to handle reverse in gearing, not in reversing the motor. The only issue I could see with that is the mechanical losses in the direction change before connecting to the prop.
How are you planning on connecting a prop to the motor? Long straight shaft similar to a mud motor or something more similar to an outboard lower unit? 12HP seems like a very small motor for a 12 ton boat but I know you are working with what you have.
I like your motor control idea using relays. I think I'd add a middle circuit of 36v for "cruising". I'm thinking once you are up to speed, you could drop down to 36v and maintain your speed but keep some heat out of the motor.
As far as circulating water, I would try a pipe pointed toward the bow as a pickup then pipe it where it needs, and dump out at the stern. Just trying to come up with a way to keep pumps, etc out of the mix if possible. I think when you are headed down the waterway, the force of water should be enough to push the water in the pipe up (depending on how far up is).
Rescued Machines
1975 John Deere 830
1996 John Deere 455
2005 Stihl FS130 Brushcutter
2017 Stihl MS362-C Chainsaw
1950's Homelite Chainsaw
1990's Troy Bilt Tiller
https://www.youtube.com/RoostersGarageHome
mda2000 is offline
Old 05-22-2019, 11:26 AM
rudedawg
This message has been deleted by rudedawg.
post #8 of 54 Old 05-22-2019, 12:51 PM Thread Starter
I installed a bow thruster on my large boat; but I've managed this one for 20 years without one, and there is no budget for that.
Alright, I'm just going to say it; I'm really very good at handling this boat.
That's the US! over on this side, that's not going to happen.
The stern of the boat is too high for an outboard; and with the rudder there's no way to mount one without some serious butchering, which would terminate my historic boat permit that allows the boat to stay in the city at all.
Also, in Europe I've never seen cheap old anything.
Separate batteries? NO NO NO! less batteries is what I want!
This boat steers with a great big tiller.
Prop to motor will be probably be with a big cogged belt, that will allow gear ratio too.
36V would be nice, but would require dropping out 2 batteries, or having a complex arrangement of 12, or a complex arrangement of 2V cells. If 24 is too low, and 48 too high, I'll switch back and forth, or just go slower.
Also, this doesn't have to be built all at once; if it really bothers me, I can always change.
6 batteries could give 24 or 36 or 72 [momentary overspeed for stopping]
There will have to be a pump or two. tried and tested, I have enough experimental stuff going on already.
tricky part is keeping the armature cool. I haven't thought of any practical way to monitor it spinning in there.
12HP is about the largest possible electric before costs head into the stratosphere. Bigger motor need bigger current, which is bigger batteries, bigger charger, etc.
Sailing and mooring up while holding the camera in one hand;
post #9 of 54 Old 05-22-2019, 01:08 PM
mda2000's Avatar
I'm not 100% sure about this, but have you thought about having a hole drilled through the armature shaft to run coolant? It would be tricky to connect something to it because whatever connector you use would have to be able to seal while spinning.
Rescued Machines
1975 John Deere 830
1996 John Deere 455
mda2000 is offline
post #10 of 54 Old 05-22-2019, 01:46 PM
No real need to cool the rotor, as oil cooled stators are common in motors. May need a small pump and heat exchanger to water.
Mark, "THEY" are the ones changing the rules, not you. Surely they would allow some modifications to your older boat to meet the new standards.
EDIT: Do you have access to a dry dock. Can you cut a hole in the underside of the hull and install a jetski drive. No props or driveshafts to interfere with the rudder, just need your electric motor to power the drive..
post #11 of 54 Old 05-22-2019, 02:42 PM
This interesting.
What are you pushing the boat with now?
Some thoughts,
Here old treadmills are readily available FREE, any number of small (1-4? hp) DC motors could be had. And they come with controls also.
The guys over on a Old Wood Working site re-purpose them for drill and lathe work.
Or a bit more $$, trolling motors, older versions w/o GPS are modestly cheap.
If you're only adding small motors, I'm not sure I'd spend much time on fancy cooling, and if you used trolling motors it's a non-issue.
A set of bow thrusters would give much greater control. (but maybe you don't have stiff wind of current in those canals)
Dan
Bolens / TroyBilt GTX20
MF / Snapper 1855
Bolens / Iseki G152
JD 116 - sold
DL-North is offline
post #12 of 54 Old 05-22-2019, 05:36 PM Thread Starter
Dan; we already covered those things above.
"They" don't give a toss about my ugly old historic boat; funny thing though, the tourists used to love it. 'Ooh look, a typical Dutch guy and his typical Dutch dog!'
Dog wasn't Dutch either of course.
The stator is air cooled; duty cycle at full power is short. If I water cool the outer case, that will absorb some heat from the middle too, but probably not enough.
Yes, I did think of drilling the shaft; thinking is as far as that goes.
I have another idea, which I could actually achieve; weld an extension to the rear of the shaft and run it through a water jacket. a lot of heat will bleed along the shaft and dissipate into the water. that requires just 1 seal.
The existing shaft and prop work just fine; there is really no need [or budget] for more.
Importantly, I can reach down from the stern to pull plastic bags out of the existing prop.
post #13 of 54 Old 05-22-2019, 06:01 PM
Please tell us more about this interesting craft Mark. What do you use it for, or transport on the deck?
What's below deck, just the engine, any equipment siorage or personal accommodations?
Do you just stand on deck and steer with the tiller?
Thanks.
post #14 of 54 Old 05-22-2019, 06:40 PM
I didn't see where either were discussed.
And you still haven't said what you are pushing it with now.
If you only need 8-10 hp, that's not much if you use DC motors.
You could easily have 3 or 4 belt driving a common shaft.
As for belts, 2 x 3/8" or 10 mm vee belts would easily handle 10-12 hp, depending on belt speed.
And trolling motors, bolt 3 or 4 to the rudder and your done, and no cooling problems.
And more pics and details please.
Dan
MF / Snapper 1855
Bolens / Iseki G152
JD 116 - sold
DL-North is offline
post #15 of 54 Old 05-22-2019, 07:54 PM Thread Starter
It's a classic Dutch utility sailing barge called a 'Westlander', about 100 years old, riveted steel on steel.
I bought the boat in 1982; it had a square steel cabin on it and we lived in it for 7 years; no rent in the middle of the city.
Couldn't get away with that anymore, and we bought a bigger boat with a permanent mooring I needed a workboat, so I cut the square cabin off and welded the flat deck on it; keeps the water out.
I bought a Mercedes OM636 36HP diesel [1965], and steer with the original tiller.
I keep my tools and workclothes in there, it airtight containers. Also scaffolding, stepladder, paints I use to maintain my houseboats.
Now we live in Portugal, and when I travel to Amsterdam it's a mobile work platform.
I often have to take ships to shipyard, and I bring the workboat too. Last time I was there, I used it to travel 10 miles to the city and back many times, since having a car there isn't practical.
I could do the journey on a bicycle in the same time, but while I'm there I work 14 hour days and don't need more fatigue.
One houseboat I have has to get under a very low bridge to get out for maintenance. I built it with a removable rear cabin, about 10' square and weighs a ton.
I have a crane come and lift it off, set it down on my workboat. I've done this many times now, always a show.
I could survive without the workboat, but it would be expensive.
ID:	2377751   Click image for larger version
ID:	2377753   Click image for larger version
ID:	2377755   Click image for larger version
Name:	propeller aug 2001.JPG
Name:	wharf5 aug 2001.JPG
ID:	2377759   Click image for larger version
Name:	om636 asembly 2.jpg
ID:	2377761   Click image for larger version
Name:	putting the wheelhouse back on in the sluis.jpg
ID:	2377763   Click image for larger version
Name:	Watergruwel under the bridge 2.jpg
Name:	putting the wheelhouse on the workboat.jpg
ID:	2377767   Click image for larger version
Name:	down the Amstel.jpg
Bill the boat addict BillBoost37 On the Open Water 8 09-26-2018 09:39 AM
