GT3100 foot pedal Drive - Lost reserve - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 17 Old 09-27-2019, 05:07 PM Thread Starter
Send a message via AIM to Icetman Send a message via MSN to Icetman Send a message via Yahoo to Icetman
I have issue with my GT3100 that developed today. I mentioned in a past post that the drive pedal were not doing what they should be doing. Finally today I lost the reserve (not in the transmission) via the pedal. So adjusted the linkage and got a .5 mph in reserve (forward stayed the same) but right before I was done mowing 2 acres I lost the reserve again and forward slowed down just a little.
Does anyone know how to fix the drive pedal problem to help solve this or is there a previous thread about it?
Icetman is offline
post #2 of 17 Old 09-27-2019, 05:23 PM
Re: GT3100 foot pedal Drive - Lost reserve
If you happen to go to the right side top of the page, you'll see the Google Custom Search Box. Enter in Cub Cadet GT3100 Reverse and you will find many threads on that topic. One of them may have just what you need.
Flaken is online now
post #3 of 17 Old 09-27-2019, 05:43 PM Thread Starter
Great will do. Guess I used the wrong wordage in the search window.
THANKS
Icetman is offline
post #4 of 17 Old 09-27-2019, 05:44 PM
Steve Urquell's Avatar
Pedal bushings. They are plastic and wear out. Here's where I changed the ones on my 3240: https://www.mytractorforum.com/19-cu...l#post12175459
You can see the part numbers in one of the pics.
Steve Urquell is online now
post #5 of 17 Old 09-27-2019, 05:53 PM
THANKS
You mean like REVERSE or RESERVE? Search engines are rather grammatically correct, but we didn't notice anything.
post #6 of 17 Old 09-28-2019, 05:43 AM
The spelling nanny strikes (again)! And here I thought it was out to get (only) me.
ChuckT is offline
post #7 of 17 Old 09-28-2019, 09:41 AM Thread Starter
EXCATLY oops I mean exactly ...
Icetman is offline
post #8 of 17 Old 09-28-2019, 09:50 AM Thread Starter
You can see the part numbers in one of the pics. Did a little work today. Replaced the pedal bushings and gained better pedal response and faster reverse.
3240 parts the same as the GT3100? New to CC so learning as I go.
Icetman is offline
post #9 of 17 Old 09-28-2019, 09:54 AM
Yep. Same stuff on most parts on the 3000 series.
https://www.partstree.com/models/gt-...trol-pedals-3/
post #10 of 17 Old 09-28-2019, 10:28 AM Thread Starter
Ok great good know. Another question, I see 4 bearings in your pic (3 big 1 small) and two different part numbers 741-3074 and 941-3073, do I need to order both these part numbers and will they have all I need or do I order 2 of each part number to get the 3 big and 1 small bearing?
Icetman is offline
post #11 of 17 Old 09-28-2019, 11:09 AM
I cant remember how many of each it has. Open the Partstree link I put in and count them. You can click on the red circles and it'll tell you which part # it is. There is another one back at the hydro. I think it's the small one but it'd be a good idea to check. You'll have to order how many you need. There isn't any kit for these. Order a couple more than you need.
I like to get my parts here. Both flange bearing#s
https://www.cubcadetpartsnmore.com/m...ng-flange.html
post #12 of 17 Old 09-29-2019, 05:45 PM Thread Starter
Thanks Steve. Saved the link (website) for the future. Do you know if there is a repair manual other than the CC website showing how to replace these and anything else on CCs? Normally I find all I need on YouTube but not did not find an instruction video on replacing these bearings.
Icetman is offline
post #13 of 17 Old 09-29-2019, 05:57 PM
There are some manuals online for it but dude , this is super simple. Just roll under it and you'll see it's just pulling a couple pins and slipping them in.
Take pics if how it goes before starting if you're worried but it's super easy. 1/5 difficulty. The only hard one to get at is at the hydro.
post #14 of 17 Old 09-29-2019, 08:52 PM
The diagram is a lot clearer on this website.
https://www.cubcadet-parts-direct.co...285-875-168649
While your in there you may want to try my bent nail modification. If no adjustments are made to the linkages it will significantly increase reverse speed. With adjustments you can increase the forward and/or reverse speed.
https://www.mytractorforum.com/19-cu...00-series.html
Joelk is offline
post #15 of 17 Old 09-29-2019, 09:05 PM
Link to page with 3000 Series(and MANY other) Service Manuals.
https://www.mymowerparts.com/pdf/Cub...epair-Manuals/
It has a LOT of useful info. I did not look to see if it covers replacement of the bushings, but the process of replacing the bushings is pretty simple, especially if you have the diagram to guide you.
NOTE: When removing the Fenders, leave the Floorboards attached and remove as an assembly. When I first started working on these, well over a decade ago, I used to take them apart and it was a PITA.
Joelk is offline
Old 09-29-2019, 09:21 PM
Joelk
This message has been deleted by Joelk. Reason: Will rewrite
