Cub cadet 3205 axle leaking - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 4 Old 09-18-2019, 06:50 PM Thread Starter
Hey guys, I have my mower shut down for right now for water pump gaskets, and I would like to take care of my axle leak while it’s down. My axle seams to be leaking a lot of oil. I pulled off brakes and hub found the plate on the end loose so I removed it and cleaned plate and area before remounting put back together and didn’t move mower at all due to waiting for pump gaskets came back out 4 days later and a huge puddle of hydraulic oil on the ground. Anybody have this issue and now what I need to do to fix it.
Christianstoneking97 is offline
post #2 of 4 Old 09-19-2019, 09:51 AM
Ejl in Pa.
Re: Cub cadet 3205 axle leaking
Sounds like you have some leaking seals. A member named Oaktodd has plenty of info he could share with you to make your repair. I'm sure he will chime in soon.
ejl6658 is offline
post #3 of 4 Old 09-20-2019, 09:09 AM
Ejl in Pa.
Here is a write up of a repair done by Oaktodd on another site. I'm sure it will resolve your issue.
https://www.onlycubcadets.net/forum/...ad.php?t=33446
ejl6658 is offline
post #4 of 4 Old 09-21-2019, 09:23 AM
Thanks EJL!
I did the write up on here too. This was on a 3165. It has the same rear as your 3205 but it didn't have the locking differential.
https://www.mytractorforum.com/19-cu...e-rebuild.html
Some of the part numbers have changed since I did mine but they are still available.
Pay close attention to the bolts for the locker. You may want to pull them and use red Loctite and re torque them.
I also did my 3205 this spring so I'll see if I can did some pics up for you.
Get us some more pics when you open it up. Also check those roller bearings. Give them a good cleaning and a good amount of lube.
Oaktodd is offline
