Cub cadet wont crank - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 13 Old 09-16-2019, 07:11 PM Thread Starter
have a cub cadet 2166 lawn tractor that wont crank. Tractor has always run great until I was mowing the other day, shut it off to take a phone call and 10 min later tried to start it and no crank. I replaced the battery aswell as the starter, battery reads 12.6 so seems like plenty of juice. Looking for other ideas on what it might be causing the problem.
Mendoza419 is offline
post #2 of 13 Old 09-16-2019, 07:26 PM
Steve Urquell's Avatar
Re: Cub cadet wont crank
Is the PTO switch turned off?
Steve Urquell is online now
post #3 of 13 Old 09-16-2019, 10:17 PM
Sofisticated-Redneck's Avatar
.......Safety Switch ........
Andrew in Tulsa OK
Running a Troy Bilt GTX20
Working on a 2nd Troy Bilt GTX20
"Parking" a Sears GT3000
"Loaned" to my daughter, a John Deere LX277
Running a Mahindra Tractor, Model 2815 HST, W/4WD & Loader
Running a Husqvarna 372 Chainsaw
Running a Husqvarna 450 Chainsaw
Have a Husqvarna 350 awaiting an overhaul
and .... storing about a dozen other "semi-running" various vintage chainsaws
Sofisticated-Redneck is offline
post #4 of 13 Old 09-16-2019, 10:30 PM
Senior Moment
Greybeard09's Avatar
Could be a safety switch gone bad, but I would look into the key switch... They are prone to problems on the 2166. It seems to be an oddball switch too from what I've read, only used on this model. I don't know what's different because I haven't replaced mine yet.
On mine it will do this sometimes but if I jump the starter with a screwdriver the key starts working again for awhile.
Late 50's Bready... aka, "The WoodRat"
1969 John Deere 110 w/front blade
1998-99 MTD/AYP "Black Thing" 18hp Briggs MUTT-Mower
2002 Cub Cadet 2166 (in process)
2006 Cub Cadet GT2544
2011 Cub Cadet Z-Force S 48
Greybeard09 is online now
post #5 of 13 Old 09-17-2019, 09:40 AM
rudedawg's Avatar
As others stated check the safety switches and make sure pto switch is off. The key switch on my 16+ year old 2166 is original and so far no issues (kow) but it is an odd ball one for sure.
Do you have a schematic and/or manual for the 2166?
rudedawg is offline
post #6 of 13 Old 09-18-2019, 12:39 AM Thread Starter
Already tried jumping starter, as far as I know should bypass all safety switches. Still doesn't turn over. I think that should even bypass basically everything.... and no motor is not seized
post #7 of 13 Old 09-18-2019, 12:42 AM Thread Starter
Yes have schematics
post #8 of 13 Old 09-18-2019, 12:44 AM Thread Starter
And PTO is deff off, if I turn the key on I can engage and disengage
post #9 of 13 Old 09-18-2019, 12:45 AM Thread Starter
What makes the least sense to me is that it wont turn over even when jumping the starter
post #10 of 13 Old 10-01-2019, 10:56 AM
If it has a solenoid on the bottom of the float bowl just jumping the starter will not let it start. The solenoid needs power to open the fuel flow to the carb.
indslpwr04 is offline
post #11 of 13 Old 10-01-2019, 11:46 AM
Senior Moment
I know you said this was a new starter, but have you bench tested it off the tractor... . Could be a bad new starter, it happens.
I may have missed it but are you sure there's voltage at the starter?
post #12 of 13 Old 10-02-2019, 07:52 AM
mrshaft696's Avatar
If you jump the starter and it doesn't spin, the starter is no good, or you are jumping it incorrectly, not grounding it right or something.
mrshaft696 is online now
post #13 of 13 Old 10-02-2019, 11:47 AM
Disregard that. I thought the new starter was spinning. Is there any attempt at the starter spinning when directly jumping it? Even if its stuck it should still click. If your using a jumper pack put the + on the starter post and the - to the block and use the on off switch on the jumper pack as a key.
