O-Rings for 3000 Series Spool Valves. - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 7 Old 08-18-2019, 08:29 PM Thread Starter
I'm rebuilding a couple 3000 Series spool valves. I have enough O-rings to do this project, but I will need to be getting some more.
I have used Buna N O-Rings that are 7/16" ID, 5/8" OD and 3/32" thickness on the spools I have rebuilt in the past and these seem to have worked fine, but I was wondering if there is a better O-Ring to be using.
After a quick search on Amazon I found that this appears to be a -111 size O-Ring and I see that they are available in Buna N(70A and 75A Durometer), Viton 75A and Silicon 70A versions.
What O-Rings are others using?
Would Viton or Silicon, be better suited to this application.
Joelk is offline
post #2 of 7 Old 08-18-2019, 08:42 PM
Steve Urquell's Avatar
I've only used Buna N on my 3240 and it sealed fine but dont have many hours on those o-rings
Steve Urquell is online now
post #3 of 7 Old 08-19-2019, 08:47 AM
Ejl in Pa.
Re: O-Rings for 3000 Series Spool Valves.
This is what I use from McMaster-Carr.
11 16 Durometer 70A (Medium) ASTM D2000, SAE J200 -20 to 250 Black 100 9262K234
https://www.mcmaster.com/catalog/125/3636
ejl6658 is online now
post #4 of 7 Old 08-19-2019, 08:57 PM
Woody in PA
Here's what I used from Grainger... jury is still out as I believe 1 of them is having an issue (as evidenced by the puddle on the floor). They were the Buna N ones and the part #'s are IKET4 for the small O-rings on the lines, 3GCH7 for the backup ring, and 1RJG7 for the 11mm x 2.5mm spool rings.
2004 Cub 3235, 48" deck, 54" blade, 45" blower, hydro angling kit, factory 3-point
woody_76 is online now
post #5 of 7 Old Yesterday, 03:02 AM
20,000 Posts & Climbing
I put buna-n in my loader valve set in 1984 and they hadn't leaked up until I retired the tractor in 2006, about 2000 hours..
TUDOR is online now
post #6 of 7 Old Yesterday, 08:47 AM
The Cub 3000 hydraulic sysyem poses more problems than other designs due to poor engineering. Too much stress on the orings as they are the only seals the spools have. They also move up and down in the spool valve body.
post #7 of 7 Old Today, 12:28 PM
There are only 2 O-rings per spool in both of the loader valve sets that I use. I recently replaced the ones in the valves for my SCUT which were an off white colour, and badly worn after only 900 hours. Buna-N is commonly black.
Buna-N is commonly used for cylinder piston seal O-rings that slide up and down in the cylinders.
TUDOR is online now
