Is there an easy way to adjust the Power Steering Assist on 3000 Series Tractors? - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 8 Old 08-09-2019, 08:01 AM Thread Starter
I have several 3000 Series tractors, with 5 currently in use.
One of them has significantly "stiffer steering" than the other 4.
The PS works and is smooth and consistent, but it takes more effort to turn the steering wheel than on the other tractors. I may even prefer the way it works, but I am wondering why it is different, and if there was some "easy" way to adjust it.
If there is an easy way to adjust, I might reduce the effort required on that one slightly and increase the effort required on the others slightly.
Joelk is offline
post #2 of 8 Old 08-09-2019, 08:43 AM
Re: Is there an easy way to adjust the Power Steering Assist on 3000 Series Tractors?
It could be most anything from a restriction in the lines, or the hydraulic pump, the control unit, the filters, etc.
With so many series 3000 tractors, I imagine you have the service manual. If not, you can get it here:
https://www.manualslib.com/manual/74...?page=1#manual
Flaken is offline
post #3 of 8 Old 08-09-2019, 11:46 AM
Ejl in Pa.
Joelk I don't see anything in the service manual for adjusting the steering pump. The difference could lie in the steering pump itself, a bind in the steering wheel shaft, or possible debris blockage in the filter screen in the charge pump on the tranny limiting flow.
ejl6658 is offline
post #4 of 8 Old 08-12-2019, 03:56 PM
Down by the battery area there is a coupling that can be tightened or loosened. Not anything to do with hydraulics or oil, it is part of the steering column. I had this issue on my basket case 3205 that I put back together. Try that and report back.
Name:	DSCN0194 - Copy.JPG
Oaktodd is offline
post #5 of 8 Old 08-16-2019, 10:50 AM Thread Starter
Attachment 2390681
Todd, how do you adjust it?
Joelk is offline
post #6 of 8 Old 08-16-2019, 04:09 PM
Ray2's Avatar
is this for non-adjustable and adjustable steering wheels?
Ray2 is offline
post #7 of 8 Old 08-16-2019, 04:31 PM
When I put this machine together I tightened it too tight and it was hard to turn the wheel. I loosened it and it works fine now. The 3205 has tilt wheel.
Oaktodd is offline
post #8 of 8 Old 08-16-2019, 06:11 PM
Ray2's Avatar
I dont have a tilt wheel and that end is not on mine
Ray2 is offline
