Oil leak - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 10 Old 07-16-2019, 08:44 PM Thread Starter
Traumajunkie's Avatar
Oil leak
Hey guys I had jacked the front of my 122 up to replace the bearings in the front wheels. Came in today to find oil all over the ground, It appears to be transaxle fluid but I am not sure why or where it would come from. The mower is sitting on jack stands at the moment so it’s not high. How do I check and replace the oil if that’s what it is and what kind should I use? Thanks
Traumajunkie is offline
post #2 of 10 Old 07-16-2019, 09:53 PM
Kubota Ronin's Avatar
Re: Oil leak
You gotta find out for sure what it is/where it came from first.
Wipe or wash it down and investigate further, report.
Kubota AMX-3
Shibaura LT16B
Kubota Ronin is online now
post #3 of 10 Old 07-16-2019, 11:22 PM Thread Starter
I took off the ball holder to repaint it but put the screws back in. It’s coming from the back and smells funky. It did not leak when level
post #4 of 10 Old 07-17-2019, 01:46 AM
Re: Oil leak
Depending on how high you have the front, it's possible the oil could have come out a vent of a transaxle (if there isn't some other place where fluid expansion can take place).
dave_r is offline
post #5 of 10 Old 07-17-2019, 07:02 AM
RBedell's Avatar
Re: Oil leak
I am not clear on what you mean. Can you explain better..??
CC models: 100, 105, 129, 1450, & 784
Only Cub Cadets
Buy: Made in the USA
RBedell is online now
post #6 of 10 Old 07-17-2019, 07:16 AM
Re: Oil leak
Personally I'm wondering if that's an attachment I want, for rough terrain...?
But yes Traumajunkie a little better info or a picture might be useful... do you mean a trailer ball?
Kubota AMX-3
Shibaura LT16B
post #7 of 10 Old 07-19-2019, 08:38 PM Thread Starter
Ronin you truly just made my day, I do have a buddy at the station that swears by a pair of underwear that cups his nuts 🏼🏼🏼... but back to the tractor. I removed the plate that holds the ball to pull a trailer or what not. Was going to repaint the front wheels so jacked the tractor up and put jack stands down at the lowest setting.. this is what I came into find.. by the way this stuff smellllllls so bad!!!
ID:	2387265   Click image for larger version
ID:	2387267   Click image for larger version
post #8 of 10 Old 07-20-2019, 01:59 AM
Re: Oil leak
Glad you got a chuckle.
I'm having a hard time making heads or tails of those pictures but did you disturb any gaskets or seals? Maybe with that rust there you inflamed a problem waiting to happen.
Something something removed the low hanging fruit... I need to behave...
Kubota AMX-3
Shibaura LT16B
post #9 of 10 Old 07-20-2019, 08:20 AM Thread Starter
I am not sure about the seal as all I did was remove the 3 bolts at the bottom and take the ball/hitch mount off. How do I check and add oil to the rear end? I can’t find anything through the forum. What kind of pictures do you need? The first pic is the oil that dropped on the ground, the second is the general area where the oil is coming from /the mount I took off and the third pic is from under the rear end
post #10 of 10 Old 07-20-2019, 08:40 AM
Re: Oil leak
I'm not familiar with your particular machine but *generally* a square hole pipe plug like that means you fill it there until it starts to run out. Ie. level with the bottom of the hole and it's full.
And how the plate is bolted on there tells me there must be a gasket between it and that reservoir tank. I'm guessing that seal got disturbed when you pulled the hitch.
'Stinky' could mean gear oil but I dunno... Hopefully over the weekend someone will chime in with further insight.
Is it still leaking?
Kubota AMX-3
Shibaura LT16B
